Hot Stepper Motor
stranger
(@stranger)
Hot Stepper Motor
hi, i have a question for you guys, it is normal if the extruder motor get really hot,im having a printer fan error and i think is because of the motor getting hot,i already checked the wires and they look fine i can't print nothing because after a few minutes my printer stop working and even if a resumen it only takes a minute to do the same again...need help 🙁
Veröffentlicht : 01/02/2018 2:50 pm
vaxxi
(@vaxxi)
Re: Hot Stepper Motor
There are a lot of threads opened with the same question, try searching before asking. Final answer from Josef is here, so it's not considered a problem.
Veröffentlicht : 01/02/2018 2:55 pm
jweaver
(@jweaver)
Its normal.. And discussed many times here.
Prusa have said that the motor can run at over 100 degrees without issue where as its actually running at 1/2 that.
Don't worry about it.. The motor is within operating range.
Veröffentlicht : 01/02/2018 3:02 pm
stranger
(@stranger)
thanks for the quick reply,now i need to find out why i have the printer fan error
Veröffentlicht : 01/02/2018 3:08 pm
