Having a hard time getting this to compile in Prusa Control
Pyredex
(@pyredex)
Can anyone else try to get this to generate Gcode? For some reason mine gets stuck at 27%.
I need 2 color stops at the very end as well ...
Wish I knew what the problem was.
Thanks!
Curt
Napsal : 18/02/2018 8:11 pm
Neolker
(@neolker)
Re: Having a hard time getting this to compile in Prusa Control
Same here, did you try Slic3r?
Napsal : 18/02/2018 8:22 pm
rufflez
(@rufflez)
Fixed
The issues is you have 2 objects. I loaded it into Slicer which thankfully was able to read it.
At the prompt, I selected no
Exported as STL and it was able to compile in Prusa Control.
BTW, sorry if the text is misaligned... I eye-balled it.
Napsal : 18/02/2018 9:00 pm
Pyredex
(@pyredex)
WOW! I can't say thanks enough. Thank you!!! I appreciate the time. I guess I'll need to learn how to use Slicer, I've been a little spoiled with PrusaControl. 🙂
Napsal : 19/02/2018 5:24 am
