First Layer issues
douglas.d2
(@douglas-d2)
First Layer issues
Hi all,
Here is my latest first layer printed after a PINDA adjustment and subsequent 1at layer calibration. I'm not sure what the problem is at this point but I think I'm getting close!
What should I start tweaking to remedy these issues? Would this be an over extrusion issue?
Thanks
Opublikowany : 19/02/2018 7:49 am
RH_Dreambox
(@rh_dreambox)
Re: First Layer issues
I had similar problems when I switched back to PLA after running PETG. The problem disappeared after I washed the steel plate with a soap solution.
Window cleaners that I used for PETG prevented PLA from attaching properly. It is important that the surface is clean and free from fingerprints, etc.
Opublikowany : 19/02/2018 8:38 am
Hi Douglas,
this looks like too much squish, try backing the Live 'Z' off a little.
Opublikowany : 19/02/2018 11:27 am
Rakku
(@rakku)
If its not the z-height, its overextrusion on the first layer.
Try turning it down from the 150% towards 100% in 5 - 10% incerements.
Helped me alot.
I print at 105% first layer height and have a perfect first layer, 150% seems just like too much.
Edit: Btw this happens if you calibrate your first layer too perfect, then the 150% first layerheight are just too much (since you dont need that much compensation anymore).
If you lower it, you should have good prints.
Opublikowany : 20/02/2018 1:45 am
imod.systems
(@imod-systems)
Looks like the same thing I was experiencing when my Z level was set too close to the bed. Try performing a live Z adjust and back it off a bit.
Opublikowany : 20/02/2018 2:54 am
