First layer calibration problem
Gary Chan
(@gary-chan)
Membre
i find my mk3 doing the calibration. leftside is thicker than right side. what should i do?
Publié : 17/02/2018 5:58 am
Gary Chan
(@gary-chan)
Membre
Re: First layer calibration problem
like this
Publié : 17/02/2018 5:59 am
ImyMe
(@imyme)
I am having exactly the same problem. Managed to make it a bit more even after playing with LCD Menu - Calibration ​- Bed level correction. I still fail to comprehend what for is the Mesh bed leveling if it can't compensate for the deviations.
Publié : 17/02/2018 12:49 pm
Sammy
(@sammy-3)
Exactly the same issues for me. Autoleveling doesn't seem to work. How can I read the calibration data?
Publié : 17/02/2018 3:10 pm
Kai
 Kai
(@kai-2)
The same for me.
Very interesting is the following fact: measured with a steel ruler, the right side of the steel sheet (printbed) declines about 0,5mm.
I hope this is right verbalized.
This means the mesh-bed-levelling must be working somehow.
But i get the same result.
The right side of the first layer calibration is a bit more squeezed than the left side.
nec aspera terrent
Publié : 19/02/2018 10:12 am
ccfoo242
(@ccfoo242)
I'm curious if some of this is caused by slight variance in the X axis or Y axis level. Like for Y axis, maybe the frame is just slightly out of whack. For X axis maybe try re-doing the step where you level it just a hair above the build plate (with steel sheet removed) prior to adjusting the height of the pinda probe.
Without knowing exactly how the auto-level algorithm works, I just wonder if it relies on these two things being near perfect.
Just my thoughts, I'm probably wrong.
Publié : 19/02/2018 3:11 pm
Kai
 Kai
(@kai-2)
A bit strange is that (at my MK3) the area of the printbed on the right get´s the better result.
Even though it is a bit lower (or a bit more away from the nozzle) than the left side.
I`m talking about max. three tenth of a mm.
nec aspera terrent
Publié : 19/02/2018 3:39 pm
Ingurum
(@ingurum)
Having the same problem, i noticed with a larger print the right side(far side of origin?) Is not sticking or narrower than the left side
Publié : 25/02/2018 12:36 am
