Firmware 3.1.3 FINAL for Original Prusa i3 MK3
marek.c3
(@marek-c3)
Hi there,
final version of firmware 3.1.3 MK3 is out!
Description of changes
Extrusion multiplier fix
In 3.1.2 firmware version, there was bug which caused, that extrusion multiplier was always set to 100%. This firmware version fixes this bug.
Selftest
In previous firmware versions, axes checks were very sensitive, which sometimes causes that selftest was failing even in cases that printer harware was ok. This was happening usually on x axis.
In current fimrware version, sensitivity of axes checks were decreased.
Temperature calibration
At the beginning of temperature calibration, there are warnings shown on LCD that user should run this calibration in certain conditions and without steel sheet. In previous firmware version, when user confirmed these messages with pressing the knob, LCD screen didn't refresh and last message stay present during calibration. This has been fixed in current firmware version and also it is now easier for user to remove steel sheet at the beginning of temperature calibration. In case that steel sheet is present, printer moves printing head and heatbed to certain position.
Supported printers
This firmware supports Original Prusa i3 MK3
Download link: https://www.prusa3d.com/drivers
Firmware flashing guide: https://help.prusa3d.com/l/en/article/r5ByKgVm69-firmware-upgrade-and-flashing
Please report any bug here: https://github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
Postato : 19/03/2018 3:13 pm
jeremytodd1
(@jeremytodd1)
Re: Firmware 3.1.3 FINAL for Original Prusa i3 MK3
Am I getting mixed up? Hasn't this version been out for a bit already?
Postato : 19/03/2018 5:17 pm
JuanCholo
(@juancholo)
yup MARCH 8, 2018 is when 3.1.3 came out.
“One does not simply use a picture as signature on Prusa forums”
Postato : 19/03/2018 5:26 pm
