[Fermé] Fine tune your MK3 X axis
Page 3 / 3
llj3663
(@llj3663)
Re: Fine tune your MK3 X axis
Going off of Number of Teeth, Dimensions: 2GT from Misumi's 2GT pulleys it looks like the pitch diameter (pretty sure that's the same as effective diameter) of a 40 tooth pulley is 25.46 mm
https://us.misumi-ec.com/vona2/detail/110302193470/?CategorySpec=00000029797%3a%3aaf
Publié : 08/02/2018 4:07 pm
Brolin Workshop
(@brolin-workshop)
Did you have an assembly for the MK3 RHDreambox? Also working in Inventor and would like a good assembly to make my 3d printer enclosure more accurate, if you are willing to share 🙂
Receiving my MK3 sometime in late feb/early march 🙂
Publié : 08/02/2018 6:31 pm
Brigandier
(@brigandier)
Brigandier, do you know what the average diameter (effective) is on a 40 tooth pulley?
Hi RHD, see Lucas' post at the top of this page for details, but it's looking like 26mm? I haven't got the calipers on it (at work currently), but looking like inner diameter on a GT2 20T is about 13mm+-, and the smooth idler is very close to that. This is why I swapped to 20T on both X and Y and called it a day, I can't imagine trying to work out a 26mm+- smooth idler in the MK3 just for the sake of having a smooth idler.
My MK3 Parts: [Bowden] [New Shoes] [TPU Micro Springs]
Publié : 08/02/2018 7:21 pm
ed
 ed
(@ed-3)
Where did you get your idlers and were the bearings notchy? I'd switch to 20T idlers just because I think toothed idlers are the proper way to go but don't want to put one on that has junk bearings.
Publié : 08/02/2018 7:59 pm
Brigandier
(@brigandier)
I ordered these. I honestly didn't do much checking on the bearing, but considering it's riding on a screw I figured it couldn't be a huge deal (and I have plenty of others to try if one fouled).
Publié : 08/02/2018 8:22 pm
ed
 ed
(@ed-3)
I'd love to know the reasoning behind the smooth idler... I'm sure the choice wasn't arbitrary.
Publié : 08/02/2018 9:05 pm
llj3663
(@llj3663)
I obviously don't know Prusa's supplier price but it's probably fair to assume that bulk ordering smooth would be much less $$$ over toothed.
Publié : 08/02/2018 9:10 pm
nathan0876
(@nathan0876)
anyone know the ETA on the official Prusa redesign of the x axis mentioned in the blog post a few weeks ago?
Publié : 08/02/2018 11:20 pm
Brolin Workshop
(@brolin-workshop)
Thanks RHDreambox, I can't answer on PM, too little activity on the forums i think.. 🙂
Much appreciated!
Publié : 09/02/2018 2:18 pm
JLTX
 JLTX
(@jltx)
Hey just landed.
Publié : 12/02/2018 6:34 pm
josh.w3
(@josh-w3)
Another user just posted a recommendation for a different refined X axis design in another thread:
https://www.thingiverse.com/thing:2786603
Anyone else tried this one out? Looks well thought out.
Unfortunately one thing that both the solution above and the newly released R2 PRUSA design lack is the split X carriage back piece for easier access to the X belt, which I thought was a great innovation by area51 and jltx. ( https://www.thingiverse.com/thing:2727523 and https://www.thingiverse.com/thing:2731484 )
Publié : 12/02/2018 7:10 pm
JLTX
 JLTX
(@jltx)
That would be easy enough to add. I already made a cut at the new Prusa config.
Publié : 12/02/2018 7:25 pm
JLTX
 JLTX
(@jltx)
I added an R2 version with back access.
Publié : 13/02/2018 1:02 am
Olef
 Olef
(@olef)
Thank you for this!
Publié : 13/02/2018 2:20 am
trinity.c
(@trinity-c)
where are the files from the first post?
Publié : 15/04/2018 4:40 am
Chris P
(@chris-p-4)
The problem most people have is due to the fact that the pulley only has one bearing in it and it sits on an m3 bolt that is not really a snug fit; therefore allowing it to wobble...
I’ve replaced my pulleys with toothed ones that have 2 bearings and your problem will dissappear...
https://reprapworld.nl/products/mechanisch/katrollen_drive_gear/gt2_driven_pulley_3mm_with_teeth/
These in particular are 10 mm wide so I hade te rework the part to create some extra clearance.
Publié : 26/04/2018 7:09 am
JLTX
 JLTX
(@jltx)
Exactly. And better yet, print your own. https://www.thingiverse.com/thing:2763870
Publié : 26/04/2018 11:21 am
metacollin
(@metacollin)
https://shop.prusa3d.com/forum/others-archive--f66/fine-tune-your-mk3-x-axis-t13853-s10.html#p64030
Publié : 19/05/2018 6:17 am
l33tfr34k
(@l33tfr34k)
Just ordered my MK3 and I was wondering if anyone has confirmed whether Prusa has fixed these issues on their latest models.
Otherwise, I will be printing new parts right away.
Also, would any of the corrected X/Y/Z parts that RHDreambox came up work on an MK2S? I would really like to fix the alignment issues that I've been having on that printer.
Publié : 01/10/2018 5:55 pm
Page 3 / 3
