File incomplete
CorpseGuard
(@corpseguard)
File incomplete
Hello there.
Someone have the same Issue? since todaysome of my sliced projekt came the Info File incomplete.
Cant solve the problem :/ Small things workes but Baby Groot and some other things from thingiverse.
Respondido : 25/01/2018 10:33 pm
CorpseGuard
(@corpseguard)
Re: File incomplete
Hmm i am the only one with this problem? That sucks...... 150$ for a program that not works.....
Respondido : 26/01/2018 10:06 pm
imod.systems
(@imod-systems)
Re: File incomplete
Would help if you provided more information, like if it was a slicer issue or not. If it's a slicer issue, it would help to know what slicer are you using. Based on what you told us, $150 for a program, I'm assuming that you're talking about Simplify 3D. If so, the Prusa MK3 is still extremely new and reliable profiles are not readily available at the moment. These things take time to develop and tune.
Respondido : 26/01/2018 10:14 pm
CorpseGuard
(@corpseguard)
Re: File incomplete
Ah forgot to say thats Simplify3D was makes the problem.
BUT i found the thing whats make the problem.
I open the G-Code with notepad and found a strange thing at the End of the G-Code. When i delete the last line it works. But i dont know why S3D put this line in the G-Code.
Respondido : 26/01/2018 10:18 pm
imod.systems
(@imod-systems)
Re: File incomplete
Whos profile are you using? The only issues I've had with S3D is under extrusion.
Respondido : 26/01/2018 10:25 pm
CorpseGuard
(@corpseguard)
Re: File incomplete
I used the MK3 FFF from Jo up here in the MK3 Forum and it starts yesterday when S3D crashed. Before the crash it works very fine. So i think the problem was at S3D. In the last line from the G-Code S3D post null null null. If i delete that the G-Code works great.
Respondido : 26/01/2018 10:28 pm
Hiro
 Hiro
(@hiro)
Re: File incomplete
I'm having a same problem with S3D and MK3. My print been failing using repetier on Raspberry Pi so I tried to print it off via SD card and it said that the file is incomplete. Same stl sliced using using S3D for MK2, it printed fine.
Respondido : 31/01/2018 4:32 am
Hiro
 Hiro
(@hiro)
Re: File incomplete
ShamusTheTinker
(@shamusthetinker)
Re: File incomplete
This still happens, and for those of us without notepad++, it looks like empty space at the end of really large files.
Respondido : 23/03/2018 9:30 pm
hofinger
(@hofinger)
Re: File incomplete
This is a known Bug for big files in S3D 4.0
Just update to 4.0.1 in which the bug is fixed.
Respondido : 23/03/2018 9:33 pm
CorpseGuard
(@corpseguard)
Re: File incomplete
Ah ok. Thanks dir the Info 🙂
Respondido : 24/03/2018 5:22 am
