[Closed] Filament sensor wiring error
John Farm 78
(@john-farm-78)
I have built my mk3 and am getting an error on selftest with the filament sensor.... I have checked the wiring, red wire to the right bttom on einsy, and white wire on top on extruder. I have received a new sensor and the problem still occurs.
Support suggested measuring the voltage on the sensor but didnt say which pins.
Suggestions?
Posted : 27/02/2018 3:04 pm
nicholas.c12
(@nicholas-c12)
Re: Filament sensor wiring error
Have you found a resolution to the filament sensor wiring error? My experience is identical to yours, original sensor caused this error despite proper assembly and a replacement sensor is producing the exact same error. I'm currently running FW 3.1.3 and completed a factory reset to no avail.
Posted : 20/03/2018 5:41 pm
Ken Hylton
(@ken-hylton)
I'm having the exact same issue. Who do I contact about getting a replacement sensor?? Have verified (multiple times) that the wiring is seated correctly and in the correct place, but the self-test always stops at "Filament sensor wiring error".
Posted : 26/03/2018 5:16 pm
Roland
(@roland-3)
I also have that same problem.
Does anybody have an update on this?
I emailed support, but sofar no reaction.
Posted : 29/03/2018 11:59 pm
Navcab4422
(@navcab4422)
I had this issue too when I built and for me its because I seated it wrong on the enisy board. Its possible to plug it in one pin to the right or left of where it should be.
Posted : 30/03/2018 2:44 pm
topherhunter@gmail.com
(@topherhuntergmail-com)
I've triple-checked the wiring, pulled and inspected the sensor, and did a factory reset (all data). Still no go on the filament sensor. Has anyone found a fix?
Posted : 13/04/2018 3:11 am
Hatrick3D
(@hatrick3d)
Same issue here: I have checkt the cable several times. It is connected correctly to both the sensor and the einsy. On the sensor, i have the white cable facing up and on the einsy, i have plugged it to the lower row of Pins with the red cable on the Right-most pin.
Still i Keep getting Filament sensor wiring error message.
Please help!!!
Thank you!
Hartmut
Posted : 14/04/2018 12:40 am
Alexander
(@alexander-3)
RE: Filament sensor wiring error: Check Firmware if upgrading from MK3 to MK3s
I know, it's been silent for a while. I had the same thing after upgrade from MK3 to MK3S and was very disappointed to learn that many hours of effort seemed to be in vain and I would have to wait for a replacement sensor. Double checked everything... to no avail. All seems right.
The forum discouraged me a bit more.  However I thought, OK this is amazing that the firmware is able to distinguish between the old and new sensor. It turned out. It cannot. There is a special firmware for each printer. What makes it a bit confusing is that they all share the same version number. So I read the last chapter of Preflight Check (which I skimmed through only). Here it was loud and clear: There is a different firmware.
I updated the to become a MK3S and self-check went like a charm. I hope this helps in case there are some more inpatient makers out there that just overlook this fact.
Posted : 13/08/2019 6:45 am
