Corrupted message wizard setup
FrankDrebin99
(@frankdrebin99)
I3 mk3:
See attached images
I got these “corrupted” messages during the wizard setup just after the refining z axis.
I assume its telling me to place back the printbed sheet?
Thanks
Louis
Postato : 01/02/2018 1:38 am
Kwaad2
(@kwaad2)
Re: Corrupted message wizard setup
Have you checked your display data cables?
I'm actually not really sure what would cause this, other than a potential wiring issue.
I'm actually curious what it is if it's not wiring though!
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Postato : 01/02/2018 1:59 am
FrankDrebin99
(@frankdrebin99)
If it was wiring, it would always be corrupted messages. I only get this during wizard setup after z axis refinement.
Postato : 01/02/2018 2:07 am
FrankDrebin99
(@frankdrebin99)
Looks like the messages are ok when no sd card is inserted during wizard calibration.
Weird
Postato : 01/02/2018 2:27 am
Dewey79
(@dewey79)
Has this always happened or just started? Could the SD card be acting as a bridge so that when it's inserted it makes the connection and a short in the wiring affects the output of the display?
I say this because there was an increase of issues with the SD card port on the printer.
Postato : 01/02/2018 2:45 am
FrankDrebin99
(@frankdrebin99)
Spoke too soon, corruption is back, no sd card!
Postato : 01/02/2018 2:50 am
CJ
 CJ
(@cj-4)
I had this exact same thing happen but only after flashing the firmware to b150. Flashed back to b143 and then back to b150 after redownloading it and have not see that message since.
Postato : 01/02/2018 2:58 am
FrankDrebin99
(@frankdrebin99)
Thanks , ill give that a try.
I just got the mk3 yesterday.
Postato : 01/02/2018 3:12 am
Olef
 Olef
(@olef)
I would try a factory reset, then re-download and re-flash the firmware
Postato : 01/02/2018 7:58 am
