[Fermé] "checksum mismatch" when printing via USB
HansenDK
(@hansendk)
My otherwise great MK3 seems to be having trouble with printing directly from USB. I am presented with an extreme amount of "checksum mismatch" errors and sometimes also erratic movements making the prints useless. I tried printing from a iMac and a Windows 7 PC, using different USB cables, different software (Cura, Simplify3D and Pronterface) in addition to printing through a high quality powered USB hub.
This is an example of what I'm getting:
Error:checksum mismatch, Last Line: 111
Resend: 112
Error:checksum mismatch, Last Line: 132
Resend: 133
Error:checksum mismatch, Last Line: 139
Resend: 140
Error:checksum mismatch, Last Line: 147
Resend: 148
Error:checksum mismatch, Last Line: 155
Resend: 156
Error:checksum mismatch, Last Line: 159
Resend: 160
Error:checksum mismatch, Last Line: 163
Resend: 164
Resend: 164
Error:Line Number is not Last Line Number+1, Last Line: 163
Resend: 164
I suspect I'm seeing the same issue as people do with OctoPi ( https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/print-stopping-and-random-movement-with-octopi-t12734.html#p57286 ).
Does anybody have any luck with printing from USB? Any suggestions on what I could do to remedy this? 🙄
Happy new year, by the way 😀
Best regards
Hansen > Greetings from Denmark <
Publié : 31/12/2017 1:07 am
slayer1551
(@slayer1551)
Re: "checksum mismatch" when printing via USB
Which firmware are you running?
Publié : 31/12/2017 1:15 am
HansenDK
(@hansendk)
Ahh, forgot to tell that... the latest one (sadly) - 3.1.1-RC4 build 143
Best regards
Publié : 31/12/2017 2:13 am
AndrewD
(@andrewd)
I had the same issue with the same firmware. I gave up and printed via SD. Sorry not very helpful but at least you are not alone.
Publié : 31/12/2017 7:27 am
HansenDK
(@hansendk)
Thanks for your reply. The "at least you're not alone" part is indeed helpful. I think I'll contact support about this, but it is still interesting to know, if anyone is printing via USB. Anyone? 😉
Best regards
Publié : 31/12/2017 12:48 pm
vaxxi
(@vaxxi)
Just successfully printed a 5 hour print with USB, using latest firmware (143) and latest Octoprint. The only catch I can think of would be that I'm using an older Raspberry Pi (the one with only 2 USB ports).
The Raspberry Pi 3 has some changes when compared to the older one (yes, I know this is not related to the USB used by Octoprint); wonder if it couldn't be somehow related, though.
I.e. those having trouble with OctoPi, try printing with an older Raspberry Pi if possible and see if there's a difference.
edit: dammit, I've jinxed it 🙂
Send: N33386 G1 X103.121 Y154.591 E0.00995*103
Recv: Error:checksum mismatch, Last Line: 33385
Recv: Resend: 33386
Also had a crash detection (but the nozzle did not seem to hit anything) and a move to the front of the bed and back, but no plastic extruded during it.
Publié : 31/12/2017 1:02 pm
HansenDK
(@hansendk)
Although my issue do not relate to OctoPrint (I'm printing from a PC), I decided to try out the OctoPi thing.
Interestingly, I see very little checksum errors, and the print seems to turn out OK ❓
So... Einsy seems to like talking to RPis and really dislike the "real" computers. I am at my wits end...
(I'm using an RPi3, so I guess it is not the RPi version that matters...)
@LeMotan: Did you only get that one checksum error? I do get some with OctiPi, but it doesn't seem to affect the print...
Best regards
Publié : 31/12/2017 2:57 pm
vaxxi
(@vaxxi)
No, there are several checksum errors. The print however appears to be fine so far. Got one more slide to the front of the bad and back, but it resumed OK.
Publié : 31/12/2017 3:07 pm
HansenDK
(@hansendk)
Had to go crazy with this and do my own tests to determine the cause of these checksum errors. I am now quite sure that this is a firmware problem and not a computer/cable/software/noise issue.
I made a GCode file moving each axis (extruder, x, y and z) very rapidly 0.5 mm back and forth to stress the gcode interpreter in Einsy. The forum system will not let me attach the file to this post, so I included it at the end of this post, if you want to try it out yourself. Just make sure that the extruder is located more or less in the center with regards to all axes. Also remove any filament from the extruder, and disable the filament sensor (mine just stopped working, so I'm just guessing).
Anyway... this is what I get back from Pronterface, when "printing" the script:
echo:Unknown command: "$2 - test extruder movements"(2)
Error:checksum mismatch, Last Line: 28
Resend: 29
Error:Line Number is not Last Line Number+1, Last Line: 34
Resend: 35
Error:No Checksum with line number, Last Line: 38
Resend: 39
Error:checksum mismatch, Last Line: 40
Resend: 41
Error:No Checksum with line number, Last Line: 43
Resend: 44
Error:checksum mismatch, Last Line: 47
Resend: 48
Error:No Checksum with line number, Last Line: 76
Resend: 77
Error:checksum mismatch, Last Line: 78
Resend: 79
Error:checksum mismatch, Last Line: 94
Resend: 95
Error:checksum mismatch, Last Line: 116
Resend: 117
Error:checksum mismatch, Last Line: 117
Resend: 118
Error:checksum mismatch, Last Line: 138
Resend: 139
Error:checksum mismatch, Last Line: 153
Resend: 154
Error:checksum mismatch, Last Line: 156
Resend: 157
Error:checksum mismatch, Last Line: 157
Resend: 158
Resend: 160
Error:checksum mismatch, Last Line: 168
Resend: 169
Error:checksum mismatch, Last Line: 185
Resend: 186
Error:checksum mismatch, Last Line: 196
Resend: 197
echo:Unknown command: "$204 - test X axis movements"(2)
echo:Unknown command: "$406 - test Y axis movements"(2)
echo:Unknown command: "$608 - test Z axis movements"(2)
The "Unknown command" lines are my crude way of including "comments" in the output to be able to follow at what part of the script the errors occur. As you can see, ALL errors happen when moving the extruder. NO errors happens when moving the other axes. Therefore, this cannot be a communication problem. I have re-run this script numerous times with the same result. The number of errors vary, but they always happen when moving the extruder.
By the way, all checksum errors disappear, when I decrease the speed of the extrusion in the first G1 line from F6000 to F600. Of cause, it is not an option to slow down printing that much.
Here is the GCode, if you dare 😉 Just copy the contents of the box to a .gcode file and print from your computer using Pronterface.
G91
M109 S195 ; Heat extruder just to prevent cold-extrusion errors
G1 E0.5 F6000
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G1 E0.5
G1 E-0.5
G4 P1000
G1 X0.5 F6000
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G1 X0.5
G1 X-0.5
G4 P1000
G1 Y0.5 F6000
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G1 Y0.5
G1 Y-0.5
G4 P1000
G1 Z0.5 F6000
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G1 Z0.5
G1 Z-0.5
G90
Best regards
Publié : 01/01/2018 5:16 pm
Erik Tais Nielsen
(@erik-tais-nielsen)
I got exact same issue printing over USB and it seems to be related to latest firmware update, as I had no issue with earlier firm ware version.
Publié : 01/01/2018 5:53 pm
Dewey79
(@dewey79)
What is the USB type on the MK3 and what type is on your computers? Just checking if connecting a USB 2.0 to a 3.0 or something different is the cause. There's been some errors with other electronics when you connect a USB 2 to the USB 3 when it came out. I haven't kept track of errors over time so I don't know if that's cleared up.
Publié : 01/01/2018 6:13 pm
lignumaqua
(@lignumaqua)
Yes, I think you are correct. My guess is that the new linear advance and crash detection code in the stepper interrupt routine is taking too long to run, and is causing the system to miss characters coming in on the serial line. This will only affect moves using the extruder. One way to check that would be to disable linear advance and see what happens. This is a tricky one.
It prints perfectly from the SD card so I don't think this is a fundamental printing issue. Rather it's the limited way that this processor has to deal with serial input.
Publié : 01/01/2018 7:25 pm
GertL
(@gertl)
Could this be solution for you ?
https://shop.prusa3d.com/forum/software-f13/checksum-mismatch-t6214.html#p43543
One other thought (this was a firmware fault I reported over 6 months ago...) OctoPi settings/Serial Connection/Advanced Options/Simulate an additional OK for resend requests - make sure you have ticked the box.
Gert
Publié : 01/01/2018 7:36 pm
HansenDK
(@hansendk)
I tend to agree with you on the Atmel microcontroller having a hard time dealing with all these new tasks. Another thread in this forum discusses OctoPi and similar issues, and people seemed to conclude that disabling crash detection helps. I re-ran my GCode file to test it, and sure enough... the number of checksum errors dropped by 90 %, when crash detection was disabled.
I really, REALLY hope that Prusa Research was right when saying that it wasn't necessary to move to a 32 bit platform for the MK3 😕
Best regards
Publié : 02/01/2018 12:20 am
HansenDK
(@hansendk)
Mmmm, as I understand the issue, I would say "no". This is not directly related to OctoPrint, and in the end this is more about preventing the resends to occur in the first place.
Best regards
Publié : 02/01/2018 12:24 am
justaguy
(@justaguy)
Has anyone rec'd help from support on this issue? I just took my MK3 out of thebox and tried to print over USB and ran into this problem. Kind of frustrating :/
Publié : 15/01/2018 6:54 pm
HansenDK
(@hansendk)
Prusa has a firmware out for initial testing here: https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/octoprint-issues-and-tips-t13156.html
It seems to do the trick for me 🙂
Best regards
Publié : 16/01/2018 3:27 am
WNC2
 WNC2
(@wnc2)
hi to all,
i have the same problem with latest firmware 3.4.1 and latest slic3r PU 1.41.1
i print via USB without problem with S3D but i receive the error if i try to print via USB with slic3r
"Error:No Line Number with checksum, Last Line: 0"
Publié : 02/11/2018 5:39 pm
