Can someone help me out with these prints
Azzatar
(@azzatar)
I everything was printing fine but I was having problems with the pla adhering the print surface so I ran the calibration. Was still having problems with sticking to the bed but got it figured out after many, many first line print calibrations. now everything seems to be fine the printer passes all self checks, and the first line print is awesome. no problems with pla sticking to the bed and the prints start out great...but then after about 1/3 of the vase and at about 4% of the castle things start to go horribly wrong. these are printed from the SD card with default PLA settings.
Posted : 07/01/2018 9:09 pm
stahlfabrik
(@stahlfabrik)
Re: Can someone help me out with these prints
Got a loose idler on your x motors shaft? Seems so! Or a loose belt?
Posted : 07/01/2018 9:22 pm
simon.m
(@simon-m)
Have you got it running in 'Stealth' mode ?
If mine is in Stealth mode then the prints shift all over the place. Knocked it back into normal and not had a layer shift since.
1st & 2nd from the left were printed off the SD card with Stealth turned on. 3rd was the same file just with Normal mode on.
Posted : 07/01/2018 11:08 pm
