Calibration Time
MareIngenii
(@mareingenii)
Calibration Time
How long should the temp calibration take? I can do the PID calibration very quickly but the temp calibration seems to hang. It's been running for over an hour now. It seemed to have checked the Pinda 3 times and then it's just sitting there with the bed on.
Postato : 09/02/2018 6:07 am
x50arm
(@x50arm)
Re: Calibration Time
Mine does the same thing, curious to see the replies.
Postato : 09/02/2018 5:14 pm
MareIngenii
(@mareingenii)
RC5 didn't even get that far. At least on 3.1.1 it does something.
Postato : 10/02/2018 1:07 am
x50arm
(@x50arm)
On 3.1.1 mine just sits at the question about the metal sheet after I acknowledge that the sheet is not installed. I can tell the heat bed is cycling on and off, but the display is just locked up with the question still displayed. Only resetting the printer has got me out of this so far.
Postato : 10/02/2018 1:49 am
MareIngenii
(@mareingenii)
Just installed 3.1.2 and actually made it all the way thru calibration!
Postato : 02/03/2018 11:43 pm
HeySideburns
(@heysideburns)
If you connect via pronterface before you start you can see output in the command window that will tell you if it is doing anything. I had the same thing happen, but I could see that it was going through a series of different temperatures in pronterface so let it complete. I can't remember how long it took though.
Postato : 03/03/2018 1:33 am
