Bug in Slic3r PE or have I missed something big?
I decided to print a test object while designing something and set my print speeds pretty high. When I popped in the SD card and let it start printing I noticed that it would speed along until it got to the infill, where it would creep along.
I know close to 0 about gcode, but opened the file anyway to find that before it starts the infill commands it sets the flow rate with the command G1 F900. That seems pretty far off, since I see a flow rate of 11031.1 for solid infill.
I've attached my sample gcode. You will see on line 444 that it sets the flow rate to ~184mm/s for the infill for solid infill, but on line 766 it only sets the flow rate to 15mm/s with the same speed set in Slic3r for the 5% infill.
Veröffentlicht : 14/03/2018 8:31 pm
