Bondtech Extruder Gears
Bigdogbro1
(@bigdogbro1)
Does anyone know of the download link available for the STEP file of the Bondtech gears used in the MK3?
Thanks!
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Opublikowany : 16/01/2018 11:17 pm
john.n13
(@john-n13)
Re: Bondtech Extruder Gears
These look to be proprietary and not open source, see http://shop.bondtech.se/ec/drivegears/
Opublikowany : 17/01/2018 1:50 am
RH_Dreambox
(@rh_dreambox)
I use these in my Inventor assembly.
The gear should be correct, but I'm not sure if the length 14 mm is correct.
My MK3 is delivery delayed so I have not been able to measure the detail, just guessed.
EDIT:
Why is the filament not centered in the bondtech gear?
Opublikowany : 17/01/2018 10:24 am
