Bed temperature correction
Kamil
(@kamil-3)
I have noticed that temperature which is shown on the LCD screen of the MK3 and one that I measured with external thermocouple is different. I have about 8 degrees difference. It shows higher than it is in reality. Is it possible to change values of thermistor or put an offset somehow? I know it may not be a big problem I can simple ad this 8 degrees in the slicer however I would like to know if there are any possibilities in the case. Thank you.
Publié : 02/03/2018 11:23 am
Re: Bed temperature correction
did you put insulating material on top of the thermocouple, if not, you may have a wrong reading, part air temperature, part bed temperature...
Publié : 02/03/2018 1:35 pm
Kamil
(@kamil-3)
Problem solved. I have just made update to Firmware 3.1.2. Now temperature is ok. Probably, I should have done factory reset before, however everything is fine now.
Publié : 02/03/2018 2:04 pm
