3.1.3 Firmware - Lin_Advance (Print Problem)
Página 2 / 3
jonathon.b
(@jonathon-b)
Re: 3.1.3 Firmware - Lin_Advance (Print Problem)
You can counter that infill but increasing permitters but I found it made no difference to it, so I found anyway
Respondido : 15/03/2018 5:54 pm
Nikolai
(@nikolai)
interesting to see one without that line, is it this model, printer or slic3r?? It’s getting complicated now! I know there’s some clever people here who can help
Yes, Yes and Yes. You can reduce extrusion width or amount for this couple lines.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 15/03/2018 6:30 pm
jonathon.b
(@jonathon-b)
How would you go about just targeting them few layers? Is that what you mean?
Do you manage to get it without them lines?
Respondido : 15/03/2018 6:39 pm
Nikolai
(@nikolai)
In Simplify3D you can define any setting per layer.
I haven't wasted time and money on that. I'm using Benchy to dial in an average good quality for small objects. There are always things to improve but there are always trade offs. That's the beauty of this Benchy.
Your Benchy from the initial screen shots do look already pretty good. Once I hit this quality with a new filament, I'm satisfied. Any other additional tweakings are happening on the model I'm printing.
Often linked posts:
Real Multi Material
Respondido : 15/03/2018 6:46 pm
jonathon.b
(@jonathon-b)
thats True S3D is good for that, Ive had it a while now. i got it when i was using dual extruders on my other printer. only reason im sticking with slic3r now is because of the MMU which should arrive (This year) and wanted to be running top notch before it comes.
the benchy im now printing looks pretty good ill post a picture when its done. Are you using the supplied S3D profile from them of Prusa as a starting point?
Respondido : 15/03/2018 7:03 pm
Nikolai
(@nikolai)
Yes, I started with it but went through many iterations. I'm using Hatchbox and Makergeeks brands. HB PLA is really forgiving but MKG PLA need to be on spot. You can see the screen shots from configuration I posted in my linked thread above.
Often linked posts:
Real Multi Material
Respondido : 15/03/2018 7:11 pm
jonathon.b
(@jonathon-b)
ill take a look, We don't get any of that in the uk. i've been using fillamentum lately. they do some cool colours especially this.... https://fillamentum.com/collections/pla-premium-filament/products/pla-extrafill-vertigo-galaxy
Respondido : 15/03/2018 7:23 pm
Nikolai
(@nikolai)
Yeah, everybody likes this filament :-). Too expensive in USA. So you have to find the right settings for you then.
Often linked posts:
Real Multi Material
Respondido : 15/03/2018 7:27 pm
jonathon.b
(@jonathon-b)
yeah its a shame you cant get UK Brands and we cant get USA brands
Respondido : 15/03/2018 7:33 pm
jonathon.b
(@jonathon-b)
Just off the printer...it’s actually looks worse in the picture than it actually is, it’s definitely an improvement using the LA firmware
Respondido : 15/03/2018 7:58 pm
robert.b52
(@robert-b52)
Unfortunately I use a RPI3 as a Octoprint server. If I've read correctly, they do not play well with LA at all.
Respondido : 15/03/2018 8:04 pm
ccfoo242
(@ccfoo242)
I wonder if this is an artifact of the early firmware's serial i/o problems that caused octoprint to not work. It was after this that i think they disabled LA while working on the other issues.
Respondido : 15/03/2018 8:30 pm
Brigandier
(@brigandier)
I have the artifact while printing from sd.
My MK3 Parts: [Bowden] [New Shoes] [TPU Micro Springs]
Respondido : 15/03/2018 8:36 pm
jonathon.b
(@jonathon-b)
Latest benchy, bed time now! Looks LOADS better
Respondido : 15/03/2018 10:39 pm
Nikolai
(@nikolai)
Looks good. Would you mind to share what you've done so far to get the improved Benchy? I think here are some MK3 user which can't believe it was printed on MK3 😉
Often linked posts:
Real Multi Material
Respondido : 15/03/2018 10:52 pm
john.v11
(@john-v11)
While this was true a while back it is not the case now. I use both V1.0 and V1.5 of LA via Octoprint connected via USB.
Respondido : 16/03/2018 1:12 am
Brigandier
(@brigandier)
Whoever had the idea of the deck infill causing this was correct. I knew it started at the deck layers and was related, but I hadn't considered it might be outward pressure from the infill. Check these two out:
The only settings difference between these two is the top partial benchy was sliced with 0 top layers, effectively disabling the deck infill for this test. Once I saw it was fixed I stopped the print. I don't have time to test tonight and maybe not tomorrow night, can you guys experiment with the Print Settings > Advanced > Infill/perimeters overlap setting? I am wondering if it is pushing these layers outward because things haven't cooled enough, maybe dropping this back 1% at a time until the issue goes away, then test if we're still getting good top layer coverage with no holes?
This one seems pretty important if you ask me. This is probably affecting dimensional accuracy in a way that isn't easily figured out.
Respondido : 16/03/2018 3:50 am
x50arm
(@x50arm)
Printed this one tonight. E-Sun PETG, Slic3rPE, Default Prusa PET profile, .2 Fast, Honeycomb infill@ 20%, and 150% scale.
Respondido : 16/03/2018 4:23 am
reid.b
(@reid-b)
LOL - almost looks identical to the one I printed today. Filamentum Extrafill PETG, Black Soul. Near perfect...
Respondido : 16/03/2018 6:58 am
jonathon.b
(@jonathon-b)
I had a feeling it was to do with that after watching the printer do its thing, your LA Firmware really helped the problem so thanks for doing that a sharing it, printing at speeds creates such a pressure in the nozzle and when it slows down to turn onto the next run the plastic has no where to go except up which effects the next layers perimeters causing the problem. I'm assuming it does happen with infill also but doesn't cause an issue due to the extra space inside the model.
Respondido : 16/03/2018 7:47 am
Página 2 / 3
