1st layer waves
paz
 paz
(@paz)
1st layer waves
hi all can any shed some like on why the 1st llayer is getting all the waves throught it...
i done slowing down,, not much chop
i done increasing the bed heat and nozzle temp.. not much chop there either..
any ideas ? anyone anyone
Napsal : 25/02/2018 9:43 am
Re: 1st layer waves
Reduce the negative size of your Live 'Z' setting,
your nozzle is probably too close to the heatbed,
Napsal : 25/02/2018 10:48 am
ToddAB
(@toddab)
Re: 1st layer waves
I had the same problem and needed to lower my z live adjust. Ripples went away and I’m printing again.
Good Luck,
Todd
Napsal : 25/02/2018 9:11 pm
Cacciola
(@cacciola)
Re: 1st layer waves
Actually for me it was just the opposite.
A lower Z height made the extrusions wider than the printer moves, so I had to raise Z height.
It is easy to overshoot a low Z height because the squished layer adhere better to the bed, but you end up with ripples / waves.
Good luck.
-Edit: Now that I saw Joan's answer. Yup, just like that.
Napsal : 25/02/2018 9:47 pm
paz
 paz
(@paz)
Re: 1st layer waves
thanks everyone for ur replies..
just a heads up as another possible cause i had to retighten up all the screws..
not sure if that was the actual cause but it all helps
Napsal : 25/02/2018 11:43 pm
