16T idlers keep failing
Matt F
(@matt-f)
After swapping the X and Y idlers to 16T I was having great results, but I've now had to replace the Y once after the tiny bearing disintegrated, and now the X started clicking/sticking and looks like the bolt ended up threading the inside of the bearing after a while.
Anyone found a quality source for these? I just grabbed a set off amazon. Wondering if its worth getting a bolt thats only threaded at the end?
Veröffentlicht : 17/03/2018 9:20 pm
Enginman
(@enginman)
Re: 16T idlers keep failing
If you decide to replace the bearings instead, this is a terrific source..
https://www.bocabearings.com/
Veröffentlicht : 18/03/2018 4:28 pm
