Where can i find STP files
kentthoresen
(@kentthoresen)
I wanted to remodel my axis guides to accomodate better bearings but several of the the stl files are corrupted.
Where can i find a stp file of the parts that can be modified to suite my needs?
Veröffentlicht : 27/12/2016 9:31 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Where can i find STP files
There are only STL and SCAD files available here: https://github.com/prusa3d/Original-Prusa-i3/tree/MK2/Printed-Parts
Peter
Veröffentlicht : 27/12/2016 9:54 am
David T.
(@david-t)
Some STL files in repository might be damaged. Either repair them in Netfabb or download SCAD sources and make new STL files from them.
If you want to make adjustments for 16mm Igus bearings, you can use these ready-to-use files: http://www.thingiverse.com/thing:1898131
Veröffentlicht : 27/12/2016 11:23 am
