[Closed] Uninterruptible power supply
Stránka 1 / 2
MrMik
(@mrmik)
I want to add an uninterruptible power supply (UPS) to my Prusa I3 MK2.
Rather than putting 240V into the stock PRUSA power supply I think it would be less complex and more energy efficient to simply power the printer from a 12V battery. As in: Remove the I3 power supply completely, and connect it's output cables directly to a 12V DC battery.
The battery needs to be connected to a battery charger which is powered by the grid. When grid power fails, then the printer keeps running until the battery is empty, or until the grid power comes back on.
Here are my questions:
1) What is the upper voltage limit for the PRUSA I3 MK2? Can it cope with 14.7V DC if the charger decides to go that high?
2) What is the lower DC voltage limit? Can the printer be left running until it shuts down due to the voltage getting too low as the battery discharges, or would it get damaged if the voltage drops slowly towards zero V? A 'battery guard' that can be set to a specific value (e.g. 12.0V) could prevent this (by quickly turning off the 12V supply when it falls to the set lower limit), but adds complexity and cost.
Thanks for any advice, Mik
Napsal : 10/10/2016 12:54 am
Re: Uninterruptible power supply
I considered batteries, then bought a small ups...
the ups is a very tidy solution. and there is no need to worry about modifying things.
also I can use the printer anywhere where as with a battery solution you would have difficulty moving the printer...
Joan
Napsal : 10/10/2016 2:26 am
David T.
(@david-t)
With battery you will get very variable power on heaters with unexpected results. I would not go this way. Use the UPS.
Napsal : 10/10/2016 8:18 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Michael
Yes, you could run off batteries - the RAMBo has an upper voltage limit of 28V I believe.
However, as David says, the problem is with the heaters which are powered from the input voltage line and you would probably end up blowing fuses on the RAMBo.
So, your options realistically are either UPS or to use a 12Volt battery with a buck and boost converter which should be capable of supplying at least 25 Amps (30 A would be preferable).
Peter
Napsal : 10/10/2016 10:02 am
robothut
(@robothut)
Use a UPS and use a back up car battery for the UPS, that way if he UPS looks like it will run out of back up power before your print is done you can connect in a out side battery to keep the UPS going.
Napsal : 28/10/2016 11:23 pm
MrMik
(@mrmik)
What size UPS is required for the Prusa i3 MK2 ?
What is the maximum power consumption, when heated bed and extruder and fans and stepper motors are all in full action?
Napsal : 29/10/2016 2:08 am
MrMik
(@mrmik)
And is a true sine wave inverter required or will a cheaper 'modified sine wave' do?
Napsal : 29/10/2016 2:14 am
I bought a Powercool 1200va UPS, seems to work Ok...
like this http://www.box.co.uk/Powercool_Smart_UPS_1200VA_1359075.html
another site says it has a squarewave invertor... so I guess it's more mangled sine wave than modified sine wave...
I have no idea how long it will run for, on the battery...
I don't particularly want to risk running it flat and ruining a print...
the datasheet says it is OK with generators... if that's a consideration...
Napsal : 29/10/2016 2:43 am
MrMik
(@mrmik)
Here is how to use an Uninterruptible Power Supply to stuff up a print:
1) Realise that the UPS draws quite a bit of standby power, even once the battery is fully charged.
2) Do the smart thing and turn the power to the UPS off when not using the printer for a couple of days.
3) Do the not so smart thing and turn on only the UPS when you start your next print.
4) Measure a hitherto seldom mentioned calibration dimension of the 'Benchy" : How thick does your printer print the Benchy when it is not connected to the main power?
I would of course NEVER do such a stupid thing, 😳 but if I had done it, theoretically, then the Benchy would have grown to 2.90mm thick before the power failed.
The UPS that I would have used (if I had done such a silly thing) is the CyberPower Bric 850VA / 510W.
I got it from Officeworks (Australia) and it works quite well so far.
Napsal : 02/11/2016 2:50 pm
These things happen. Like clearing the blocked U bend on the sink And then tipping the waste water into the same sink. Before reattaching the U bend... 8-(
Joan.
Napsal : 02/11/2016 5:12 pm
1 lidem se líbí
Nigel
(@nigel)
When the mains fails, it is often not clean. Auto reclose breakers on High Voltage network etc. Maybe eventual lockout on permanent HV fault. LV faults may blow your your local substation fuse. Transients on the LV feed to your house. Whatever event the delay in the uniinterruptable power supply to take over will wreck a print, so don't bother. Waste of money. We have a realible supply here, and I live in a rural Town.
If the printer remembered where it was before the glitch maybe have saved the day. We need stepper feedback and true position information. And other parameters ie hotend temp and bed temp before carrying on with a print.
Nigel
Napsal : 03/11/2016 6:12 am
MrMik
(@mrmik)
W...
Whatever event the delay in the uniinterruptable power supply to take over will wreck a print, so don't bother. Waste of money. ...
I don't think so. Time will tell, because power outages are not all that uncommon where I live. Lots of thunderstorms.
Napsal : 03/11/2016 10:01 am
PJR
 PJR
(@pjr)
Agree totally with Michael
We have overhead power lines and thunderstorms twice a year. I have my printers powered via an APC UPS (3000) which also provides power for my server and workstation. I have never lost a print due to momentary power outage (there are many of these) nor any short power cuts.
Only time I lost a print was when I didn't check the provider's web site and they had a planned 12 hour cut on a Saturday. The UPS did manage to last for almost 4 hours though...
I think there may be a clue in the name of the device: "Uninterruptable Power Supply"...
Peter
Napsal : 03/11/2016 10:48 am
David T.
(@david-t)
+1
UPS can last long enough to cover all common power outages. In case of long outage (longer than one hour) it provides enough time for me to get mobile generator and plug the UPS into it to save valuable print if necessary.
Napsal : 03/11/2016 11:34 am
PJR
 PJR
(@pjr)
David
Nigel is suggesting that switch-over from mains supply to UPS power takes too long and the printer will not be able to handle the split-second down time.
That is certainly not my experience with either computers, monitors nor 3d printers. My guess would be that his suggestion is based around cheap and nasty £50 UPS devices which most of us would not consider a workable solution.
Peter
Napsal : 03/11/2016 12:37 pm
David T.
(@david-t)
That is very unlikely to happen.
Switching power supply of the printer itself (without UPS) can withstand about 100-300ms of power outage, depends of actual power consumption. Any UPS should provide satisfying results as long as its output power is sufficient for the printer (250W).
Napsal : 03/11/2016 12:52 pm
ayourk
(@ayourk)
There are different kinds of power supplies out there. Some are switching, some of them run the devices off of battery all the time and keep the batteries charged while doing so when mains power is available. It all depends on how much you want to spend for the UPS.
Dimensions PNG
and an 8 inch (200mm) or greater caliper is recommended.
Napsal : 03/11/2016 4:14 pm
Nigel
(@nigel)
Yep how much you want to spend and how much your print time is worth? A good UPS (Uninterruptible Power Supply) will probably cost more than your 3D printer.
I never leave prints running when out of the house.
In the last 34 years that I have lived here in my rural town (overhead line network) I have had less than 10 power outages. A few seconds/ minutes to a max so far of 8 hours < on one Christmas Day. (Even in the so called England hurricane of 16th Oct 1987, we were off supply for just over 4 hours, only)
A UPS is a waste of money and they need maintenance, more money and if neglected!!!! why bother . Transients bugger up 3D printers more and get through UPS.
I know some countries like the USA and others have 3rd rate/world power supply systems. We Power Engineers built well here. A shame that our government lacks vision in the energy sector, and ignores the base load at their peril. Our margins are getting lower as more coal fired and nuclear powerstaions are due for retirement and come off the grid. (Hint... Renewables are not reliable coverage for base load, the wind doesn't always blow and the sun does not always get through a cloudy day when you need them most, ie weather is random, no way to cover realiably a base load)
Also renewables are paid to not generate via subsidies when over supply is concerned.
Often in the winter we have a countrywide anticyclone ie no wiind low sun angle and temperatures well below zero deg centigrade. That can last for many days. The base load generators would be the only coverage. ie fossil fuel coal and gas powerstations and fossil free nuclear power stations. Many due to be shutdown soon, here in the UK.
Nigel
Napsal : 05/11/2016 3:34 am
richard.l
(@richard-l)
Member Moderator
For the purposes of supplying a 3D printer for a few minutes a good UPS will only cost ~$100. Definitely NOT near as much as my MK2.
This is your choice. Staying at home or leaving has no bearing on when the power may go off. If your home or away when the power flickers or goes out for 10-15 seconds your print is ruined without a UPS
What maintenance? I check the battery on the 3 in my house monthly. That's it, no other maintenance is required.
Wow! Do you even know the extreme distances that power has to be delivered to some parts of the US? Some of the extreme weather we have to deal with? 100F for 100 straight days in Texas. -10 to -50F in Minnesota. Here's a size comparison of just the state I live in...
Napsal : 05/11/2016 4:17 pm
ayourk
(@ayourk)
Again, there are several factors that play into making this statement either true or false. Not all UPSs are made the same. Some are switching like this yes, but not all of them.
Dimensions PNG
Napsal : 05/11/2016 6:40 pm
Stránka 1 / 2
