Thinking about adding a cooling fan
nathan.d
(@nathan-d)
Has anyone added a fan to cool the object being printed? When I print with PLA I get some edge curing up on overhanging corners. I am thinking that adding a fan blowing on the print will reduce the curling. I've also seen comments on the other forums that a cooling fan might help with bridges in ABS.
Thanks
Napsal : 12/08/2015 6:05 pm
russ.j2
(@russ-j2)
Re: Thinking about adding a cooling fan
Did you try the fan yet? Are you talking about using an additional on-board fan that is attached and directed at the nozzle -or- a small desk type sized fan aimed at the print bed? I have not yet printed in PLA, but as you mentioned - I have experienced some (minor) bridging problems using ABS.
Napsal : 27/08/2015 12:48 am
Hitman13429
(@hitman13429)
The new 1.75 head assembly has a fan that blows on the tip and part.
Napsal : 29/08/2015 4:07 am
petasto
(@petasto)
I actually added a fan. Print results has improved significantly.
Napsal : 29/08/2015 2:44 pm
nathan.d
(@nathan-d)
Petr that looks great. Can you share the designs and how you did it? Did you plug the fan into the other fan socket on the RAMBO?
Thanks,
Nathan
Napsal : 07/09/2015 9:48 pm
