Thermister Wire
delaney.a
(@delaney-a)
Thermister Wire
I have had 2 replace the Thermister wire twice now in 2 weeks time. I have assembled the wire exactly per the documentation, but that damn wire is so fragile it breaks and then gives me a err mintemp bed and I cannot print. I have looked to see where it is pinching and cannot find it. Any after market wires or ways to make sure this does not get damaged. I THINK the bed covering and and zip tie may be the cause. I tried re-enforcing the wire more, but that did not fix. This is So frustrating.
I know it is the wire as I can move the bed just a tad and the wrror appears. I can move the wire and the error appears.
Napsal : 20/07/2017 4:45 pm
AJS
 AJS
(@ajs)
Re: Thermister Wire
Look at the placement of the wire when the printer does an X home (e.g. moves all the way over to the left). I had a bad routing of my thermistor wire, and that X-home move pinched it. It would work for a while, but then become intermittent. Since re-routing it has been stable.
Napsal : 21/07/2017 2:49 am
