Suggestion for glues
Guys
Do you have any suggestion for gluing metallic inserts in printed parts ? I dont want to solder them in.
I am looking at loctite ultra gel, not sure how it works on metal to plastic bond
I have brass, coated steel and stainless steel ones. Plastic is Colorfabb XT
Re: Suggestion for glues
a Cyanoacrylate glue should be fine for securing parts , though a two part exoxy glue may also work for something with loose tolerances
2 part epoxies tend to be a lil messy.
Cyanoacrylate is superglue right ? Any brand suggestions for people in the US ?
Loctite Ultra Gel should work just fine.
2 component glue
But I find it much nicer embedding those pieces in the print. Just Insert a pause in the g-code - put thing in - continue printing
PRUSA MK2
- Noctua fan 40mm
- MK2/MK3 hybrid extruder
Try super glue and baking soda for an instant weld.
