[Geschlossen] Smooth vs. Toothed Idler Pulleys
Omikron
(@omikron)
I've searched around for a good bit now, and I don't seem to have a clear answer on this...
What is the reason that smooth idler pulleys were chosen instead of toothed ones? Beyond cost, is there any potential disadvantage to toothed pulleys?
Veröffentlicht : 14/10/2016 12:02 am
JohnOCFII
(@johnocfii)
Re: Smooth vs. Toothed Idler Pulleys
It is the same on my other printer too. My first thought was that the designers didn't want two toothed gears fighting each other, but I guess that doesn't make sense since only one is powered.
Veröffentlicht : 14/10/2016 5:24 am
David T.
(@david-t)
Smooth idler is way easier to manufacture. 😉
Veröffentlicht : 14/10/2016 7:58 am
Falcon
(@falcon)
What size is the idler pulley on the mk2? The build instructions just say 623 bearing housing.
From what I've seen in previous discussions on this, toothed pulleys potentially give longer life of the belts and do not deform the teeth, but the general thought is that this may be important for an industrial machine that runs around the clock, most printers do not run those kinds of hours in their life, and so it is not a real concern.
Veröffentlicht : 24/10/2016 3:49 am
Snype
(@snype)
RE: Smooth vs. Toothed Idler Pulleys
Has anyone found an answer to this?
Veröffentlicht : 19/06/2020 8:25 pm
After the bearings were defective i changed my smooth idler pulleys on both axes (X/Y) against this one:
https://www.amazon.de/gp/product/B07LF7CJ8D/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
alternatively this one:
https://www.amazon.de/gp/product/B071J86YFX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
depending on printer type.
Veröffentlicht : 19/06/2020 11:04 pm
