[Chiuso] Pump Bottles
GertL
(@gertl)
Pump Bottles
Bought some pump bottles from Aliexpress for div cleaning fluids.
Works really good.
https://www.aliexpress.com/item/210ml-Empty-Pump-Dispenser-Liquid-UV-Gel-Polish-Nail-Art-Polish-Remover-Cleaner-Acetone-Bottle-Polish/32696391162.html?spm=a2g0s.9042311.0.0.2I8iE7
Gert
Postato : 02/03/2018 12:14 pm
volker.g2
(@volker-g2)
Re: Pump Bottles
Thanks for the Idea!
Postato : 02/03/2018 12:40 pm
Dewey79
(@dewey79)
Re: Pump Bottles
What is the advantage of these bottles over their original containers?
Postato : 02/03/2018 3:14 pm
GertL
(@gertl)
Re: Pump Bottles
Flip the lid open, put a piece of paper on top and pump a couple of times.
Gert
Postato : 02/03/2018 3:16 pm
Dewey79
(@dewey79)
Re: Pump Bottles
Thanks, I've never used this kind of container. Now that I think of it when I was in Jr H and HS the sciense labs had them....
Postato : 02/03/2018 3:26 pm
gary.b
(@gary-b)
Re: Pump Bottles
Do they leak if accidentally tipped over?
MK2S & Mk3 my mini farm is alive 😆
Postato : 02/03/2018 3:34 pm
GertL
(@gertl)
Re: Pump Bottles
Just tried to held them up-side down.
I comes a few drops nothing alarming.
Gert
Postato : 02/03/2018 3:48 pm
Dewey79
(@dewey79)
Re: Pump Bottles
What are the different chemicals used for and when do you use them?
1. I know the Windex can be used instead of laying down glue to allow the first layer to adhere to the build plate. What else can be used? I remember glue sticks.
2. ACETON, is this only used for smoothing the surfaces of a print?
3. Used also for better adhesion for first layer. I read also it can be used for smoothing.
Postato : 08/03/2018 4:41 am
GertL
(@gertl)
Re: Pump Bottles
1. Yes, i use windex when printing PETg, Using this it is very much easier to get the PETg print off the bed.
2. Once in a while I clean the bed with acetone, especially when have printed ABS. It removes dirt very well from the bed. I use IPA to clean between every print. Aceton just once in a while.
3. You can smooth ABS with aceton also, never done it mysef though.
Gert
Postato : 08/03/2018 10:16 am
Kevin
(@kevin)
Re: Pump Bottles
I use acetone between every print, I don't have any issues with IPA, it's just that I'm too lazy to go all the way up to my room to get my bottle of IPA when I already have the Acetone in the basement
Postato : 17/03/2018 2:58 am
