[Closed] Prusa i3 MK3 Bearing Holders
ahargreaves77
(@ahargreaves77)
Hi, I am the fng so forgive if this is covered. Wobbly bed is the problem, fixed with thing:3558209 Bearing Holders. No wobble now, prints coming out perfect. U bolts in the bin where they belong...Oh Min Temp and Min Bed Temp both fixed by replacing cheap PVC wire with 18 AWG silicone wire, just cut 50mm from thermistor same at plug end and solder new wire in, heat shrink to insulate.
Napsal : 02/07/2020 1:30 pm
