[Zamknięte] PRUSA blackPC Edition
Strona 1 / 2
Knickohr
(@knickohr)
Member Moderator
Kickohr proudly presents :
The PRUSA blackPC Edition 😀
Printed all parts in black Polycarbonate (PC plus), except the Rambo-cover, the PSU-cover and the LCD-cover.
Will print my LCD-cover in ESD-safe ABS (of course in black).
I found a nice display at Chinese ebay.
Yes, really white characters on black background 😎 Perfect for the blackPC Edition :geek: Looks like an OLED, but it isn't.
Thomas
Opublikowany : 09/06/2017 10:27 pm
Kolous
(@kolous)
Re: PRUSA blackPC Edition
You think it will print better when you change color of parts?? 😯
Opublikowany : 10/06/2017 9:09 am
JeffJordan
(@jeffjordan)
Member Moderator
don't think Thomas believes that it'll print better due to the color of the parts... but it looks cool and has a personal touch.
but beside the color, you may see at his pictures that he uses some altered parts, like the whole extruder with the 40x40 print fan and the modified air flow channel. or his x-carriage, where he mounted the igus bearings with housing...
Opublikowany : 10/06/2017 11:34 am
Knickohr
(@knickohr)
Member Moderator
It prints much better with the black color ! It's like an replicator on spaceship Enterprise :mrgreen:
Nonsens !
I searched for a orange colored Polycabonate but I didn't found one, except on Chinese ebay.
There are some improved parts :
- the complete extruder body (all parts are modified)
- x-carriage (igus RJZM-01-08) and fixed the bug that the belt is rubbing on the x-end idler
- x-end motor (igus RJZM-02-08)
- x-end idler (igus RJZM-02-08)
- y-axis clips for igus RJZM-01-08
- 3 point y-motor holder
- y-motor brace
- improved y-idler
- improved y-belt holder (now available with the MK2s)
- alternative PSU holder
- strain relief for x-motor
- z-axis top bearing (for testing, not tested until now)
- filament guide
- filament filter
- extruder idler screws button
- tool holder for z-frame
Thomas
Opublikowany : 10/06/2017 10:36 pm
StephanK
(@stephank)
Quoted for truth 🙂
Do you happen to have a link for the black display?
Opublikowany : 11/06/2017 1:25 am
Knickohr
(@knickohr)
Member Moderator
http://www.ebay.de/itm/291020233945
Orange Display ? http://www.ebay.de/itm/281833433208
(serch for "(2004,20x4) lcd <color>" worldwide)
Sad the OLED does not work 100% 🙁
Thomas
Opublikowany : 11/06/2017 10:02 am
Knickohr
(@knickohr)
Member Moderator
Part one to the step to the Prusa blackPC edition is done : The complete extruder :ugeek:
Fan and camera works well.
Thomas
Opublikowany : 29/06/2017 11:38 am
Knickohr
(@knickohr)
Member Moderator
Step 2 :
Exchange of the rods and bearings
Thomas
Opublikowany : 30/06/2017 9:53 am
JASII
(@jasii)
When you print your LCD cover you may want to use the Color Change feature as I did here. Change to white was at .80, back to black at 2.15
- MK3s w/Mosquito Hotend- Mini w/Copperhead Hotend- XL - 5 tool -OpenScad -3d Builder -FreeCAD -Alibre -OctoPrint/x3(Pi3B)
Opublikowany : 01/07/2017 4:19 am
Knickohr
(@knickohr)
Member Moderator
That's a great idea ! 😎
Thomas
Opublikowany : 01/07/2017 9:04 pm
federico.m5
(@federico-m5)
Thomas
is the black wire the PINDA? what about the position ?
Opublikowany : 04/07/2017 10:45 pm
Knickohr
(@knickohr)
Member Moderator
The black wire in front is the endoscope camera. The Pinda is at the same position as usual.
Thomas
Opublikowany : 04/07/2017 11:04 pm
Knickohr
(@knickohr)
Member Moderator
ESD safe LCD cover 😎
Yes, there are still some parts not in black Polycarbonate 😮
Now I will give the "old" new extruder fan design another try. Problem was an overextrusion with the new 0.9° extruder motor.
Prints very nice Benchy's 🙂
Thomas
Opublikowany : 14/07/2017 11:21 am
shane.t
(@shane-t)
How did you get the x-carriage to print without warping with the PC-Plus? I have tried everything I can think of in an enclosed printer 260 print temp and 110 bed. Freshly washed PEI. Always get the warping on the long sides.
Opublikowany : 08/08/2017 7:21 am
Knickohr
(@knickohr)
Member Moderator
How did you get the x-carriage to print without warping with the PC-Plus ?
Use ordinary glue stick and a 5mm brim 😉
Thomas
Opublikowany : 08/08/2017 10:15 am
shane.t
(@shane-t)
Thomas
You are a genius. It worked perfectly. I wonder why they don't mention this on their instructions. Side note, does this work for most PCs or just PC-Plus?
Second question, how much did you scale up the model to account for the PC-Plus shrinkage? 0.5% or somewhere around there?
Opublikowany : 09/08/2017 5:56 am
Knickohr
(@knickohr)
Member Moderator
Gluestick is the means of choice for all warping problems 😉
I don't know if this is advisable for all PC's, I only use PC-Plus & PC-Max. I also do not rescale the model.
Thomas
Opublikowany : 09/08/2017 9:39 am
Knickohr
(@knickohr)
Member Moderator
The PRUSA blackPC edition evolves !
Still waiting for the MK2.5 upgrade kit, so I do an modified BEAR-mod. It's also modified because I didn't get precutted v-slot extrusion here in Germany. So I use the I-type 20x40. It's the same extrusion as my YAC housing.
Mounting the drilling helpers (modified !) :
Drilling the frame, the position of the holes moved 2mm outside and 2mm in height as the original BEAR-upgrade :
Premounting the new frame. All printed parts are adapted to the I-type extrusion and I use metallic corners with printed caps/feet :
Opublikowany : 07/03/2018 4:51 pm
Knickohr
(@knickohr)
Member Moderator
(next post because I can only add 3 pics in one post)
Mounting the PRUSA frame :
and the heatbed, also the modified z-motor holder :
I also modified the PSU-case and the y-belt holder.
Printer in action :
You can download all modified parts from thingiverse. It's a complete set.
https://www.thingiverse.com/thing:2817789
Thomas
Opublikowany : 07/03/2018 5:19 pm
Calire
(@calire)
Hum excellent work. I like it.
If i do that i think i rename as MK2.9 Perso hé hé.
Thank you.
Opublikowany : 08/03/2018 11:11 am
Strona 1 / 2
