Premature Print Stop
I have seen this problem twice. Both times on long prints (20hr>). The print stops before it is complete and the print head does not return to the "finished" location. I was printing the "pangolin" from Thingiverse. http://www.thingiverse.com/thing:2064359 and my print stopped at about 30mm of the total 45mm print. The strange thing was that the LCD screen had counted down to 99% before it stopped. I am a NOOB and I do not understand how to decipher the gcode... It seemed to me that it was complete. I am using Slic3r Prusa Addition. The following is the end of the g code.
Thanks for any help-
Tim
M204 S800
G1 F900.000
G1 X111.570 Y109.358 E0.33427
G1 X111.909 Y108.310 E0.02870
G1 X112.110 Y108.411 E0.00585
G1 X121.589 Y117.890 E0.34931
G1 X121.690 Y118.091 E0.00585
G1 X120.699 Y118.411 E0.02713
M204 S1000
G1 X120.527 Y118.906 F7200.000
M204 S800
G1 F900.000
G1 X111.094 Y109.473 E0.34758
G1 X111.661 Y107.719 E0.04802
G1 X112.357 Y108.067 E0.02029
G1 X121.933 Y117.643 E0.35285
G1 X122.281 Y118.339 E0.02029
G1 X120.584 Y118.887 E0.04646
M204 S1000
G1 X120.430 Y118.518 F7200.000
G1 F5760
G1 X119.026 Y117.342 E-0.76000
G1 E-0.04000 F2100.00000
G1 Z45.200 F7200.000
G1 X120.972 Y118.100 F7200.000
G1 E0.80000 F2100.00000
M204 S800
G1 F900.000
G1 X111.900 Y109.028 E0.33427
G1 X112.075 Y108.489 E0.01477
G1 X121.511 Y117.925 E0.34773
G1 X121.029 Y118.081 E0.01321
M204 S1000
G1 X120.857 Y118.576 F7200.000
M204 S800
G1 F900.000
G1 X111.424 Y109.143 E0.34758
G1 X111.830 Y107.888 E0.03435
G1 X112.301 Y108.124 E0.01372
G1 X121.876 Y117.699 E0.35285
G1 X122.112 Y118.170 E0.01372
G1 X120.914 Y118.557 E0.03279
M204 S1000
G1 X120.763 Y118.187 F7200.000
G1 X121.076 Y117.846 F7200.000
G1 F900.000
G1 X112.154 Y108.924 E0.04306
G1 F5760
G1 X113.705 Y110.476 E-0.76000
G1 Z45.350 F7200.000
G1 X111.755 Y108.813 F7200.000
M204 S800
G1 F900.000
G1 X111.999 Y108.057 E0.02068
G1 X112.244 Y108.180 E0.00716
G1 X121.820 Y117.756 E0.35285
G1 X121.943 Y118.001 E0.00716
G1 X121.187 Y118.245 E0.02068
G1 X111.797 Y108.855 E0.34602
M204 S1000
G1 X112.086 Y108.589 F7200.000
G1 X112.058 Y108.554 F7200.000
G1 F900.000
G1 X121.446 Y117.942 E0.28440
G1 F5760
G1 X119.894 Y116.391 E-0.76000
G1 Z45.500 F7200.000
G1 X121.495 Y117.893 F7200.000
M204 S800
G1 F900.000
G1 X112.085 Y108.482 E0.34676
G1 X112.168 Y108.226 E0.00701
G1 X121.774 Y117.832 E0.35397
G1 X121.545 Y117.906 E0.00627
M204 S1000
G1 X121.456 Y117.495 F7200.000
G1 F5760
G1 X119.990 Y116.358 E-0.76000
G1 Z45.650 F7200.000
M107
G4 ; wait
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M107 ; turn off fan
G1 X0 Y200; home X axis
M84 ; disable motors
; filament used = 61002.7mm (146.7cm3)
; avoid_crossing_perimeters = 0
; bed_shape = 0x0,250x0,250x210,0x210
; bed_temperature = 55
; before_layer_gcode =
; bridge_acceleration = 1000
; bridge_fan_speed = 100
; brim_width = 0
; complete_objects = 0
; cooling = 1
; default_acceleration = 1000
; disable_fan_first_layers = 1
; duplicate_distance = 6
; end_gcode = G4 ; wait\nM104 S0 ; turn off temperature\nM140 S0 ; turn off heatbed\nM107 ; turn off fan\nG1 X0 Y200; home X axis\nM84 ; disable motors
; extruder_clearance_height = 20
; extruder_clearance_radius = 20
; extruder_offset = 0x0
; extrusion_axis = E
; extrusion_multiplier = 1
; fan_always_on = 1
; fan_below_layer_time = 100
; filament_colour = #FF14E2
; filament_diameter = 1.75
; filament_max_volumetric_speed = 0
; filament_notes = "List of materials tested with standart PLA print settings for MK2:\n\nEsun PLA\nFiberlogy HD-PLA\nFillamentum PLA\nFloreon3D\nHatchbox PLA\nPlasty Mladeč PLA\nPrimavalue PLA\nProto pasta Matte Fiber"
; first_layer_acceleration = 1000
; first_layer_bed_temperature = 55
; first_layer_extrusion_width = 0.42
; first_layer_speed = 70%
; first_layer_temperature = 215
; gcode_arcs = 0
; gcode_comments = 0
; gcode_flavor = reprap
; infill_acceleration = 2000
; infill_first = 0
; layer_gcode =
; max_fan_speed = 100
; max_print_speed = 100
; max_volumetric_extrusion_rate_slope_negative = 0
; max_volumetric_extrusion_rate_slope_positive = 0
; max_volumetric_speed = 0
; min_fan_speed = 85
; min_print_speed = 15
; min_skirt_length = 4
; notes =
; nozzle_diameter = 0.4
; only_retract_when_crossing_perimeters = 0
; ooze_prevention = 0
; output_filename_format = [input_filename_base].gcode
; perimeter_acceleration = 800
; post_process =
; pressure_advance = 0
; resolution = 0
; retract_before_travel = 1
; retract_layer_change = 1
; retract_length = 0.8
; retract_length_toolchange = 3
; retract_lift = 0
; retract_lift_above = 1
; retract_lift_below = 199
; retract_restart_extra = 0
; retract_restart_extra_toolchange = 0
; retract_speed = 35
; skirt_distance = 2
; skirt_height = 1
; skirts = 1
; slowdown_below_layer_time = 25
; spiral_vase = 0
; standby_temperature_delta = -5
; start_gcode = M115 U3.0.9 ; tell printer latest fw version\nM83 ; extruder relative mode\nM104 S[first_layer_temperature] ; set extruder temp\nM140 S[first_layer_bed_temperature] ; set bed temp\nM190 S[first_layer_bed_temperature] ; wait for bed temp\nM109 S[first_layer_temperature] ; wait for extruder temp\nG28 W ; home all without mesh bed level\nG80 ; mesh bed leveling\nG1 Y-3.0 F1000.0 ; go outside pritn area\nG1 X60.0 E9.0 F1000.0 ; intro line\nG1 X100.0 E12.5 F1000.0 ; intro line
; temperature = 205
; threads = 4
; toolchange_gcode =
; travel_speed = 120
; use_firmware_retraction = 0
; use_relative_e_distances = 1
; use_volumetric_e = 0
; wipe = 1
; z_offset = 0
; dont_support_bridges = 1
; extrusion_width = 0.45
; first_layer_height = 0.2
; infill_only_where_needed = 0
; interface_shells = 0
; layer_height = 0.15
; raft_layers = 0
; seam_position = nearest
; support_material = 0
; support_material_angle = 0
; support_material_buildplate_only = 0
; support_material_contact_distance = 0.1
; support_material_enforce_layers = 0
; support_material_extruder = 1
; support_material_extrusion_width = 0.35
; support_material_interface_extruder = 1
; support_material_interface_layers = 0
; support_material_interface_spacing = 0
; support_material_interface_speed = 100%
; support_material_pattern = rectilinear
; support_material_spacing = 1.5
; support_material_speed = 50
; support_material_threshold = 40
; support_material_with_sheath = 0
; xy_size_compensation = 0
; bottom_solid_layers = 7
; bridge_flow_ratio = 0.8
; bridge_speed = 20
; ensure_vertical_shell_thickness = 1
; external_fill_pattern = rectilinear
; external_perimeter_extrusion_width = 0.45
; external_perimeter_speed = 25
; external_perimeters_first = 0
; extra_perimeters = 0
; fill_angle = 45
; fill_density = 20%
; fill_pattern = cubic
; gap_fill_speed = 40
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = 0.45
; infill_overlap = 25%
; infill_speed = 60
; overhangs = 0
; perimeter_extruder = 1
; perimeter_extrusion_width = 0.45
; perimeter_speed = 40
; perimeters = 3
; small_perimeter_speed = 20
; solid_infill_below_area = 0
; solid_infill_every_layers = 0
; solid_infill_extruder = 1
; solid_infill_extrusion_width = 0.45
; solid_infill_speed = 40
; thin_walls = 0
; top_infill_extrusion_width = 0.45
; top_solid_infill_speed = 30
; top_solid_layers = 9
Re: Premature Print Stop
Do you print from SD card or via USB?
You mentioned 99% on LCD, so I presume SD card. Make sure you correctly eject SD card from OS before you take it out from SD card reader slot. If you don't, you may end with the file not fully written to SD card.
Thanks- I do "eject" the SD card from the computer.
David-
I checked the gcode on the SD card and you are correct- the code is truncated as compared to the file on the computer. I'll check the card in the future to be sure that the file has saved properly.
Thanks again for your help!
Tim
