PLA Extruder Body
pottedmeat7
(@pottedmeat7)
PLA Extruder Body
Is there any extruder mount that can be printed in PLA ?
Would like a backup mount but don't want to buy ABS just for this piece...
Napsal : 17/04/2017 6:14 pm
david.b14
(@david-b14)
Re: PLA Extruder Body
May be possible with this PLA:
bioFila plaTec
http://two-bears.eu//index.php?k=44
If you have a laser temp gun, take the temp of the extruder ABS plastic when pre-heating, does it go over 115C / 239F ?
Can anyone with a FLIR device take a reading?
Napsal : 17/04/2017 6:31 pm
JeffJordan
(@jeffjordan)
Member Moderator
the biofila platec filament even has a higher vicat-temperature than most of the abs stuff, so it would be the best choice for the extruder body.
but it's quite expensive !
if you've got a reliable fan to cooldown the coldend of your extruder, the temperature of the extruder body shouldn't exceed 55°C "in normal operation mode", so even standard pla would do.
but if you print inside an enclosure, or a very hot environment, i would rather choose the safer option with platec or abs.
Napsal : 17/04/2017 8:08 pm
pottedmeat7
(@pottedmeat7)
Hmm Guess its worth it to get a roll of that.
Although Can I order the parts printed in that from somewhere, the prusa shop?
Probably won't need the whole roll... Also is it easy to print?
Napsal : 17/04/2017 10:52 pm
JeffJordan
(@jeffjordan)
Member Moderator
it's very easy to print... like pla.
i used to print it at 215/55°C. no warping, perfect layer bonding (at this temperature).
but it sticks like hell at the printbed.
so it's a good idea to add "mouse-ears" to the *.stl file, so that you've got something from which you can start to lift it off from the pei sheet, like in this picture:
Napsal : 18/04/2017 12:51 am
