New Y bearings
Manux
(@manux)
New Y bearings
Hi
I use these to reduce the noise from the carrige. Having good results so far 🙂
-> http://orballoprinting.com/en/home/82-igus-drylin-r-rj4jp-01-08-.html
What do you think ?
Posted : 12/09/2016 1:03 am
Ben
 Ben
(@ben)
Re: New Y bearings
so the 8mm fit perfectly?
Posted : 12/09/2016 9:34 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: New Y bearings
Ben
I have them fitted to my Mk1.
However, they are designed to fit inside a metal case and not with cable ties, so they do introduce some additional lateral movement, but I have not seen a problem with my prints so far.
Peter
Posted : 12/09/2016 9:40 am
Manux
(@manux)
Re: New Y bearings
YES!
@Ben,
I use super glue to fix them to the zip ties and it works very well but to be honest i doubt it was necessary as the original bearings also move a bit inside the zip ties....
Posted : 12/09/2016 9:50 am
3Delight
(@3delight)
Moderator Moderator
Re: New Y bearings
There's a discussion on this over on https://www.facebook.com/groups/Prusai3users/ , scroll down and you should spot it...
Posted : 12/09/2016 1:51 pm
Ben
 Ben
(@ben)
Re: New Y bearings
Yes I though I might be able to carry on the argument here 😆
Seems they fit x and y but not the z.
Posted : 12/09/2016 4:51 pm
gz1
 gz1
(@gz1)
Re: New Y bearings
They are drop-in replacements for LM8UU's.
I have these installed on my Y-axis currently, and they seem to be working reasonably well.
My Y bearings, straight from PR, were bad. The rattled pretty badly.
For starters, I never liked the way the bearings are mounted with zipties, so I have them sitting on actual printed blocks. I lose like ~6.5mm height putting the bearings on these blocks, but I can live with that.
There is still some play if you force it by hand, but less play than what I had with the bad LM8UU's.
But that's also because I had the prescience to buy at least 6 of them so I could pick the tightest 3. That seems be the biggest issue when using these bearings, and that's why the reports of the performance of these bearings are so varied.
I think these bearings should be biased in some way in order to take up the slop. You get a little of that with gravity on the Y-axis and the natural interference between the smooth rod misalignment.
Posted : 12/09/2016 6:56 pm
Ben
 Ben
(@ben)
Re: New Y bearings
For those in the UK or anywhere else. There is a guy selling them cheap on the facebook group 😉
Posted : 12/09/2016 9:30 pm
Manux
(@manux)
Re: New Y bearings
I just upgraded my printer x axis with these and its remarkable how silent they are 🙂
I have read about the issue with the tolerance and there are aluminium enclosures for those bearings but i will with without them first as the ones with the aluminium cost a lot like 6 Euro each. Also i wold have to rediesign the extruder part and to buy a wooden y-carriage to make the new ones fit. Wich is a lot of work and money. So i will see how these go.
After all the printer is designed to work with normal bearings who can be quite sloppy at times....
Posted : 14/09/2016 1:16 pm
Ben
 Ben
(@ben)
Re: New Y bearings
I have some on the way so I will also update when fitted. I cannot wait to hear the difference.
Posted : 14/09/2016 4:50 pm
