[Zamknięte] MK3 MMU?
3Delight
(@3delight)
Moderator Moderator
MK3 MMU?
For the MMU for the MK3 I was hoping to see the direct drive motor left on the extruder body and the other motors used to feed the filament to it for loading, this should be easy now that the MK3 has a filament sensor and would surely get rid of a lot of the problems people report with the MMU would it not? Direct drive seems to work better than Bowden from what I read. Also this would surely allow them to reduce the waste that is purged as they will know exactly how much filament is flowing?
I was disappointed to see the preorder for it go up and it's just the old version with filament sensors and BondTech gears...
Opublikowany : 25/02/2018 5:22 pm
Dewey79
(@dewey79)
Re: MK3 MMU?
If you search for MK3 MMU there are several posts already. They've moved the delivery from early Feb 2018 to May and is why I canceled my order. Few people think there will be a substantial difference between the current MMU and the one for the MK3.
Opublikowany : 25/02/2018 5:39 pm
Colin
(@colin-4)
Re: MK3 MMU?
I did a search and couldn't come up with where the MMU upgrades had been pushed back to May, except for new orders. Did I miss something?
MK3 ordered together with Multi Material upgrades start shipping early March 2018, majority in March and April.
New MMU for MK3 orders - separate and combined both - at the beginning of May 2018.
Opublikowany : 26/02/2018 1:14 pm
Dewey79
(@dewey79)
Re: MK3 MMU?
Colin, have they posted yet what the MMU for the MK3 will be? Is it just modified for the MK3 physical differences or is there actually a difference and better product?
Opublikowany : 26/02/2018 7:24 pm
Colin
(@colin-4)
Re: MK3 MMU?
As far as I know the only difference is the addition of filament sensors (the MK2 MMU comes with Bondtech gears already).
Opublikowany : 27/02/2018 3:54 am
supermerill
(@supermerill)
Re: MK3 MMU?
There are some problem with that: the filament need to cool and harden before going again into the bondtech gears. But in the mmu, the filament is cooling in the cooling tube. So, to make it work, you may have to let the filament cool in the ptfe, inside the heatsink. If so:
1- you have to change the slic3r gcode (hard coded for now)
2- it will slow the print even more.
3- i don't think it will solve the clogs problems (it's a heatbreak size & pfte size problem). But it can enable you to print with flexible.
Opublikowany : 27/02/2018 4:38 pm
Laird Popkin
(@laird-popkin)
Re: MK3 MMU?
Interestingly, Prusa just announced that the MMU 2.0 will be hybrid - one motor to feed one of multiple filaments to the extruder, and a direct drive extruder. I'm hopeful that it eliminates the 'Y' that seemed to produce problems, and will work with TPU. Fingers crossed!
Opublikowany : 03/03/2018 10:19 pm
Steve
(@steve)
Re: MK3 MMU?
Removes the Y splitter from the old multimaterial where many people experienced jams.
Given that the blog post this information comes from literally mentions that, I think you can rest assured that it does.
XL (5T) / CORE One / MK3S+-MMU3 / MK3S / Mini / SL1S
Opublikowany : 05/03/2018 7:46 am
Dewey79
(@dewey79)
Re: MK3 MMU?
I wonder if the size of the purge block will be affected. Increase, Decrease?
Opublikowany : 11/03/2018 10:07 pm
Re: MK3 MMU?
I understand that waste will be used for infill where possible!
Opublikowany : 12/03/2018 1:20 am
Peter L
(@peter-l)
Re: MK3 MMU?
The amount of purge required probably won't change, but the new software to use infill for purge will make a difference.
But that feature should be available to old MMU1 upgrades, since it's a software thing.
Opublikowany : 12/03/2018 6:17 pm
Laird Popkin
(@laird-popkin)
Re: MK3 MMU?
I am psyched about the MMU 2.0. It's not only direct drive, which means it'll work with TPU and other soft filaments, but it's only got two motors, so it's both lower cost and able to support more materials!
And using infill as 'purge' is brilliant! Since infill has to be printed, and nobody cares what color it is, it's a great way to purge old colors. Though you may still need an external purge if there's not enough infill on a given layer.
Opublikowany : 19/03/2018 2:54 am
JASII
(@jasii)
Re: MK3 MMU?
... it's only got two motors, so it's both lower cost and able to support more materials!
From the pictures I count three motors.
Two at the top left and right (position to filament? + load/unload filament?)
One on the extruder (print)
But, then, who is counting as long as it works and is here in 2018! 😉
- MK3s w/Mosquito Hotend- Mini w/Copperhead Hotend- XL - 5 tool -OpenScad -3d Builder -FreeCAD -Alibre -OctoPrint/x3(Pi3B)
Opublikowany : 19/03/2018 3:37 am
Laird Popkin
(@laird-popkin)
Re: MK3 MMU?
Sure, but the extruder motor is already there, right. So, I suppose I should be more precise - the MMU 2.0 adds only two motors, while the MMU added 3 (plus you had to move the extruder motor to drive the fourth color of filament).
And I am with you - as long as it works and arrives this year, I'm happy!
Opublikowany : 19/03/2018 5:18 am
