MK2/MK3 hybrid extruder for MK2
tijn.v
(@tijn-v)
I made a hybrid from the MK2 and MK3 extruder so you can easily fit a 40mm fan and MK3 fan nozzle on your MK2/MK2s
I seen a few of these being made already but i liked non of them so made my own version.
Uses the MK2 idler, bearing and gear + the MK3 cover and fan nozzle.
Can be mounted on the original Prusa MK2 X-carriage but works better with the MK2.3 X-carriage in the files. (slightly better hole alignment and more space for the motor + fan cables)
Will fit the MK2 P.I.N.D.A probe and lines up with the calibration points.
Can be assembled with the MK2 bolts and nuts.
https://www.thingiverse.com/thing:2735475
Napsal : 28/12/2017 7:25 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: MK2/MK3 hybrid extruder for MK2
looks pretty cool.
thumbs up !
Napsal : 28/12/2017 9:46 pm
tijn.v
(@tijn-v)
Added MM version!
Napsal : 29/12/2017 4:23 pm
tobias.k3
(@tobias-k3)
Great thanks! I was waiting for that 🙂
There is another Hybrid extruder on thingiverse (not from me) which uses the MK3 files as starting point. https://www.thingiverse.com/thing:2717534
I have still no idea which one I should try first ❓ ❓ 🙄
PRUSA MK2
- Noctua fan 40mm
- MK2/MK3 hybrid extruder
Napsal : 02/01/2018 3:46 pm
tobias.k3
(@tobias-k3)
I gave your model a try (see made one on thingiverse). Works nice so far!
PRUSA MK2
- Noctua fan 40mm
Napsal : 06/01/2018 12:29 pm
tijn.v
(@tijn-v)
Thanks!
I also added a modified MK3 X-carriage.
Napsal : 07/01/2018 5:18 pm
tijn.v
(@tijn-v)
Updated all files!
Napsal : 19/02/2018 9:55 am
