Minor improvement for nozzle fan MK3i
Hello,
While mounting the MK3 kit I broke the column where the screw is inserted on the nozzle fan. The column is very narrow at the points where the screw hole is positioned and maybe I put too much pressure on the screw.
Anyway, I was able to finish mounting the kit and the first piece I printed was a nozzle fan replacement with improved strength on the column. Here is the modified version if you are interested.
Posted : 25/02/2018 11:53 am
