Manual should mention extruder calibration
BMan
 BMan
(@bman)
The manual should include a section about calibrating the extruder steps per mm... I've been printing with 10% under-extrusion for weeks 😳
Respondido : 27/04/2017 5:40 pm
T.McD
(@t-mcd)
Miembro
Re: Manual should mention extruder calibration
Hello BMan,
Would you mind sharing what Extruder Calibration test you used to come to the conclusion you were 10% under-extruding? It sounds like your calibration test may be of great value to someone like me who is still learning. Thank you!
Respondido : 03/05/2017 8:23 am
BMan
 BMan
(@bman)
The technique is described here:
http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/new-option-calibrate-e-in-firmware-3-0-10-alpha2-t2905.html#p22580
Respondido : 03/05/2017 5:07 pm
kevin.r5
(@kevin-r5)
Further explanation here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/calibrate-extruder-e-steps--t4066.html#p31508
-Kevin
Respondido : 04/05/2017 12:21 am
