[Solved] Issue with raised text and numbers
Kevlar
(@kevlar)
Hello,
Trying to print out a model with raised text and numbers. Using .4mm nozzle. Retraction length: 0.8 and Lift Z: 0.6. Any suggestions why the top of the text and numbers and in between them have bumps and extra plastic? Is it simply because I need a small nozzle? Like .15mm? Image of final model.
Best Answer by JoanTabb:
Hi Maincityimp.
when you insert the pictures, could you please click Link To: Media File?
this will allow people to click on the image, and see a larger version
as for the spike... you could try reducing the Flow rate / Extrusion multiplier a little or take off Z lift
A smaller nozzle may help at the expense of longer print times.
0.15 mm nozzle would be a challenge, try 0.25mm  as it will be easier to work with, and Prusa have a ready made profile available via Calibration Wizard
Posted : 05/09/2019 7:55 pm
RE: Issue with raised text and numbers
Hi Maincityimp.
Posted : 05/09/2019 8:06 pm
locktec liked
Kevlar
(@kevlar)
Thank you, Joan
Posted : 17/09/2019 3:36 pm
