Increasing the Z axis height to 60cm on the MK2 or MK3
devilhunter
(@devilhunter)
I'm thinking on ordering the MK3 kit in a few weeks, but since i have a normal-ish MK2 (some heavy mods on it) i want to build the MK3 like the haribo mod (with alu extrusions) to a printable z height of about 60cm or so.
Besides new motors, long lead screws, longer rods, motor to leadscrew adapters, and cable lengths what else would i need?
I'm thinking a alu extrusion z-brace to get rid of the wobble.
What negative impacts could i get with this height modded i3 MK3?
Postato : 04/12/2017 6:26 pm
ir_fuel
(@ir_fuel)
Re: Increasing the Z axis height to 60cm on the MK2 or MK3
You would need an entirely new Z frame.
Postato : 24/12/2017 3:36 pm
Could you make y axis longer,more easily?
Joan
Postato : 24/12/2017 8:13 pm
ir_fuel
(@ir_fuel)
That would require new belts (easy), longer rods (easy), an update to the firmware (easy) and a bigger build plate (impossible)
Postato : 25/12/2017 9:24 pm
MrMik
(@mrmik)
Joan
I think that would be more difficult because it affects the auto-calibration. You would need a print bed with the calibration points embedded.
Postato : 26/12/2017 2:27 am
MrMik
(@mrmik)
Warping and print objects tearing themselves apart due to it would be more of a problem.
I think cable breakage might also increase.
Postato : 26/12/2017 2:29 am
mmmmmmmmmmmmm
(@mmmmmmmmmmmmm)
The bigger you go (in any axis) ...print quality will suffer. "Horses for courses."
Postato : 26/12/2017 6:02 am
