High speed feed rate on first layer setup
chris.m19
(@chris-m19)
My printer EEProm settings are set for a maximum z speed of 600mm/s.
When I use Prusa Slicr, I get gcodes moving z at 7800mm/s
The printer responds to this and moves up from zero to the first layer height very rapidly. sometime the z is messed up, I think because it may be missing steps.
here is the code offending code is on the last line
; generated by Slic3r 1.36.2-prusa3d-win64 on 2017-09-04 at 20:27:37
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; first layer extrusion width = 0.40mm
M107
M104 S210 ; set temperature
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
; Filament gcode
M109 S210 ; set temperature and wait for it to be reached
G21 ; set units to millimeters
M82 ; use absolute distances for extrusion
G92 E0
G1 Z0.200 F7800.000 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Publié : 05/09/2017 3:52 am
AJS
 AJS
(@ajs)
Re: High speed feed rate on first layer setup
You can alter this in the "Starting GCode" section of Slic3r.
Publié : 05/09/2017 4:04 pm
chris.m19
(@chris-m19)
How do you change the gcode produced by slicr in start up gcode?
Publié : 05/09/2017 5:37 pm
AJS
 AJS
(@ajs)
Printer Settings -> Custom G-code
Publié : 06/09/2017 3:49 am
