Extruder wires loose at Rambo Box
tom.b6
(@tom-b6)
Since I built and began using my MK2S, the cables from the extruder have been working their way loose from where they enter the Rambo box at the top. No matter how many times I secured them, the cable wrap would slip it's way up and I could see that the cloth covered wires were showing some wear. The single wire tie was insufficient.
I made a small object that allows using additional wire ties to secure the cables and wrap.
If anyone else is have the same problem, it can be downloaded here https://www.thingiverse.com/thing:2391494
Postato : 18/06/2017 1:43 pm
christophe.p
(@christophe-p)
Utenti Moderator
Re: Extruder wires loose at Rambo Box
Simple and clever, I love it 🙂
I'm like Jon Snow, I know nothing.
Postato : 19/06/2017 2:09 pm
Jonathan SCE
(@jonathan-sce)
Did you have part of the cable wrap inside the box or did it also start pulling the wrap out too? Also did you push the filament into the small hole inside the enclosure?
Postato : 20/06/2017 4:46 pm
tom.b6
(@tom-b6)
The wrap was as far down as I could get it inside the Rambo box and the tie was on the wrap. The filament was well into the box as well. Before this mod, the wrap would slowly, over many hours, work its way out.
Postato : 20/06/2017 10:21 pm
