Extruder fan specification ?
Page 5 / 13
chriszero
(@chriszero)
Re: Extruder fan specification ?
Here is a another 30 to 40 mm fan adapter designed by me, It's not "airflow-optimized", but work well. I'm using it for a couple of weeks now. The temperature of the heatbreak is about 5°K higher as with the original fan.
https://www.thingiverse.com/thing:1827477
Chris
Publié : 22/10/2016 6:22 pm
ayourk
(@ayourk)
Chris
One of the problems of having a straight flush non-angled adapter like this is, does it interfere with the X-axis endstop? This is one of the reasons my adapter is angled at 25 degrees.
Dimensions PNG
and an 8 inch (200mm) or greater caliper is recommended.
Publié : 22/10/2016 7:14 pm
David T.
(@david-t)
It does not. I'm testing its capabilities just now. There is clearance of about 2-3mm between the fan and left Z lead screw.
Cooling performace results will follow in 10 minutes.
Publié : 22/10/2016 7:40 pm
David T.
(@david-t)
Christian's adapter cooldown time is 9m19s. Almost the same result as Patrik (only few seconds worse), but mechanical design is the best so far (for me).
Publié : 22/10/2016 7:58 pm
Omikron
(@omikron)
Perhaps the best option here would be actually doing the airflow analysis and redesigning the extruder part itself. Then we don't have to figure out how to mount it securely while having smooth flow.
Publié : 23/10/2016 3:03 am
Patrik Rosén
(@patrik-rosen)
I'm done with this project, it works as it should for me and that's enough, I hate over designing, and I have too much to print/work with atm 🙂
The few percentage difference between different designs isn't enough for me at least to keep designing. The average temperature inside my apartment changes more than that between sunny morning --> dull / rainy evening 🙂 I'll come back here if I experience some long term problems/issues with the replacement Noctua fan! Great work all of you involved!
Me on 3dhubs!
Me on MyMiniFactory!
Me on Instagram
3D Printing Live Feeds
Prusa MK2 Usergroup Slack Live Chat
Unofficial live chat by users for users.
Publié : 23/10/2016 5:15 pm
JohnOCFII
(@johnocfii)
Do you have a comparison against the stock fan?
Publié : 23/10/2016 6:23 pm
David T.
(@david-t)
You can find it in this thread.
Publié : 23/10/2016 7:42 pm
JohnOCFII
(@johnocfii)
Original fan extruder cooled down in 6m46s. Noctua fan extruder was at 69°C at the same moment.
Thanks. I had looked, but clearly, not closely enough, as I had missed it.
Publié : 23/10/2016 8:24 pm
Patrik Rosén
(@patrik-rosen)
http://shop.prusa3d.com/forum/improvements-f14/extruder-fan-specification--t1524-s50.html#p16252
Me on 3dhubs!
Me on Instagram
Publié : 23/10/2016 8:34 pm
Omikron
(@omikron)
That's quite understandable, Patrik, and for what it's worth your huge contribution is deeply appreciated. Perhaps someone else will take this idea and run with it a bit further, but if not, I think you've gotten us quite far already.
Thank you again for the push forward!
Publié : 24/10/2016 2:27 am
Patrik Rosén
(@patrik-rosen)
The strength of the 3D printing community 😀
Me on 3dhubs!
Me on Instagram
Publié : 24/10/2016 7:07 am
christophe.p
(@christophe-p)
Membre Moderator
Thanks a lot for your contribution to the community 🙂
However I think I will try to find a stronger fan, I do not feel comfortable having a fan that is cooling with an important difference time from the stock one, even if it seems ok in your case.
I'm like Jon Snow, I know nothing.
Publié : 25/10/2016 3:44 pm
Patrik Rosén
(@patrik-rosen)
Please shout out if you find a better one! I'm still not ready to give up this quietness 😀 (Currently negotiating a second printer with the wifey, the low noise level really helps lol)
Me on 3dhubs!
Me on Instagram
Publié : 25/10/2016 4:40 pm
ayourk
(@ayourk)
I forgot to mention this earlier: Does your MK2 Live Feed have audio, or is it just that quiet? 😀 😀
Dimensions PNG
Publié : 25/10/2016 4:57 pm
Patrik Rosén
(@patrik-rosen)
haha no audio 😀 That would be nice though!
Me on 3dhubs!
Me on Instagram
Publié : 25/10/2016 5:22 pm
David T.
(@david-t)
I should say it seems OK in my case as well. I did my measurements just because I was curious. I did very long test print with PLA and a lot of retractions, with no problems.
We'll see in summer, when air temperature rises 15-20°C higher than now.
Publié : 25/10/2016 8:33 pm
christophe.p
(@christophe-p)
Membre Moderator
I was looking on farnel site, I found some reference of alternative fans. What is a bit annoying is that the product list does not seem to be the same on french and US site :/
SUNON  MC30101V2-0000-A99  is a 30 mm * 10 mm fan, with a bit higher cfm (4.6), intermediate static pressure (0.12 '' = 3 mm if I'm not mistaken in the conversion) for a decent 20 dBA nois level. But quite expensive, ~25 €.
For the 40 mm fans, the SANYO DENKI seems interesting: 11.7CFM and 14dBA. No information regarding static pressure. Quite expensive again, ~29 €
a good candidate seems to be, SUNON  EB40201S2-0000-999  MAGLev® motor, 20 mm, 7.7 CFM, 21 dbA and 0.16 '' (= 4 mm ?) , while being cheaper, ~12 €.
Publié : 26/10/2016 12:02 am
ayourk
(@ayourk)
My experience with SUNON in general is that they don't last. I could be wrong though.
Dimensions PNG
Publié : 26/10/2016 12:06 am
christophe.p
(@christophe-p)
Membre Moderator
I have no experience in fan durability :/
Do you know if ADDA is reliable ? They make another interesting fan regarding the specs: ADDA AD0412LB-C73GP(P) (6.4 CFM, 19 dB, 0.15inch H2O) and pretty cheap, can be found at 5 €
(Edit: Well 5€ if you order 500, otherwise close to 20 € ...)
Publié : 26/10/2016 12:31 am
Page 5 / 13
