Extra current path for Heater bed using Fuse tap
david.b14
(@david-b14)
Hello,
I was thinking about adding an extra positive pathway for current to make it from the Rambo to the heater bed using the fuse tap shown below.
Any suggestions on where I should add a parallel negative wire?
Napsal : 25/11/2016 1:07 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Extra current path for Heater bed using Fuse tap
Tell me, how will the additional power be switched?
Peter
Edit: Here's the circuitry. Note the negative is switched via the mosfet.
Napsal : 25/11/2016 10:54 pm
david.b14
(@david-b14)
In looking at the schematics, I see your point. I guess I will just solder the wires right below the terminal screws on the bottom of the rambo board and perhaps use a deans connector.
Napsal : 26/11/2016 6:03 pm
PJR
 PJR
(@pjr)
David
I really do believe that it best to cut out all mechanical only connections for the high currents if you are having issues with those already present.
I agree that deans connectors should be OK, but is it worth the risk?
You could double-up on the positive rail, bue that still leaves a problematic negative (switched) rail.
Peter
Napsal : 27/11/2016 7:35 pm
david.b14
(@david-b14)
Good point. I will just leave one connection which will be the heat bed wires directly solder to the underside of the Rambo board.
Napsal : 28/11/2016 1:31 am
