Enclosure Lighting, Temp, & Octoprint
cory.w
(@cory-w)
Does anyone have any good set-ups or suggestions for lighting inside an enclosure and controlling it via Octoprint? I know there is a plugin that controls the I/O of the raspberry pi. My goal would be to turn on a small set of LED lights or something when a print is activated.
Additional, I plan on just making a simple enclosure with the lack tables with plexiglass that has about 1/4 inch gap between panel and frame so it has some ventilation. Don't want to make a fancy ventilation system but I do want to add a temp sensor to the I/O of the Pi that will cancel print if the enclosure exceeds a high internal temp for some reason. More of a safety thing.
Napsal : 13/06/2017 4:53 am
christophe.p
(@christophe-p)
Member Moderator
Re: Enclosure Lighting, Temp, & Octoprint
Hi Cory,
you probably should have a look to this plugin: https://github.com/vitormhenrique/OctoPrint-Enclosure
I'm like Jon Snow, I know nothing.
Napsal : 13/06/2017 11:28 am
