Colorprint Color Change Layer counterintuitive
chad.r2
(@chad-r2)
Just trying ColorPrint for the first time. Pretty cool. The only think I found a bit confusing was exactly which layer to enter for the color change. The instructions state to Set the heights in mm where the color change will occur. I wanted the color change to occur at 1.1mm, so color 1 would be from 0 to 1mm and then hoping it would stop, allow color change, then start 1.1mm with the new color.
Turns out it changes color AFTER that layer prints...so it printed color 1 from 0 - 1.1, then 1.2 and onward with the new color.
Maybe it's just me in that this expectation, but either way to be more clear it should specify a bit more clarity. i.e. "Set the height in mm where the color change will occur after it prints. i.e. the color change will occur after this layer prints." or something along these lines.
Postato : 28/08/2017 5:07 am
chad.r2
(@chad-r2)
Re: Colorprint Color Change Layer counterintuitive
No one else is having this issue?
Postato : 14/09/2017 3:08 am
Intrudermax
(@intrudermax)
I did make the same mistake using Colorprint to pause a print to insert items into chambers. I guess it just depends on design POV.
Postato : 16/09/2017 2:07 am
chad.r2
(@chad-r2)
So in ColorPrint webpage, I added a color change at 2.15.
Here is the GCode:
G1 Z2.650 F7200.000
G1 X228.613 Y168.813 F7200.000
G1 Z2.150 F7200.000
M600
G1 E0.80000 F2100.00000
M204 S2000
G1 F3600
G1 X227.337 Y168.471 E0.03348
G1 X227.264 Y168.535 E0.00247
G1 X227.956 Y171.750 E0.08333
Should the color change prompt on the printer occur before or after 2.15 begins printing?
Postato : 20/09/2017 7:25 am
HAMMER_T
(@hammer_t)
I have tried one time with ColorPrint, but the result was very strange. The printer made the outer perimeter 3 in the original color and then executed the M600 command.
Postato : 20/09/2017 11:04 am
