best way to replace a nozzle
I am building my MK3 and I have recieved an Olsen Ruby nozzle. What is the best way to replace it? I believe it needs to be done from a heated state, Is this corect?
-Bryan
Posted : 01/02/2018 1:33 pm
Re: best way to replace a nozzle
here is the link to the guide on how to do this.
http://help.prusa3d.com/l/en/article/fJa7GxLSG6-changing-or-replacing-nozzle
Posted : 01/02/2018 3:09 pm
Change it after you are happy with the machine as supplied.
Regards Joan
Posted : 01/02/2018 6:59 pm
Heated, use crescent wrench to hold heat block and 7mm socket to loosen nozzle. Socket will catch nozzle tip as it disconnect and attempt to fall
Posted : 13/03/2018 4:18 pm
