[Cerrado] Best $7 buck improvement you can make
Página 1 / 2
jordan.c
(@jordan-c)
16 inch stone paver, about 4 bucks
4 big rubber feet, about 3 bucks
Noise, down about 80%
Prints, noticable better
Here are someore pictures
https://goo.gl/photos/R3Lts9Qcms4Prz8s6
Respondido : 22/01/2017 5:31 pm
Cees me gusta
Foxandxss
(@foxandxss)
Re: Best $7 buck improvement you can make
I am completely with you, that is absolutely no noise at all. I guess it is silence mode tho, right?
Respondido : 23/01/2017 9:33 pm
Wirlybird
(@wirlybird)
Mine sits on feet I made from Semi-Flex and then on my granite counter top and it is silent also. So great idea with the paver.
Respondido : 30/01/2017 9:51 pm
Rob Cole
(@rob-cole)
Too cool. I have 6 of those pavers under my workbench (we were forced to remove some by our condo association). Thank you for posting this. It will be happening here too.
Respondido : 31/01/2017 2:29 am
penguin
(@penguin)
It's a great tip!
How heavy is the paver block? In metric it's about 40.64 cm x 40.64 cm x 5 cm.
Respondido : 31/01/2017 5:27 am
David
(@david-19)
I was wondering, there's a USB cable running from the Rambo card to something hidden behind the frame of the Prusa. Is it some kind of networked repeater to command the printer ?
Respondido : 01/02/2017 3:24 am
richard.l
(@richard-l)
Miembro Moderator
David,
Looks to be a Raspberry Pi. It is used to control the printer instead of having it connected to a PC or having to use the SD card to shuttle gcode back and forth to print.
Respondido : 01/02/2017 3:47 pm
Gelap
(@gelap)
Thank you, adding a paver and a foam mat made a huge difference!
Respondido : 20/03/2017 12:29 am
Saulius
(@saulius)
That looks mighty cool!
I'm wondering though, how heavy is a typical paver? I'm planning on building a LACK enclosure, and I'm not sure how well the paper honeycomb inside will handle the weight...
Respondido : 20/03/2017 10:02 am
Falcon
(@falcon)
My paver is listed online as 40 pounds (18.14 kg). I have it on a giant mouse pad that I was already using under the printer. I am not in low power mode, but it is significantly quieter. I can be in the same room without any real issues. It sounds about as loud as you would expect a printer to now. My Y axis is still the noise maker.
Respondido : 28/03/2017 2:24 am
penguin
(@penguin)
I bought a granite plate under five dollar.
Dimension of the granite plate: 400x400x30 mm
It really reduces vibration and noise of the printer. 😀
Respondido : 07/04/2017 2:40 am
tobias.k3
(@tobias-k3)
I can't compare but I am quite happy with these isolation feet: http://www.thingiverse.com/thing:2205774 You can use some HIFI absorbers which are about 10 EUR on amazon. Works nice and no wobbling . 🙂
PRUSA MK2
- Noctua fan 40mm
- MK2/MK3 hybrid extruder
Respondido : 12/04/2017 11:06 pm
keith.l2
(@keith-l2)
That is a great idea, the noise in the evenings drives my wife crazy even though it is in the garage. I just cut up a spare mouse mat and found a left over large floor tile and it has made a huge reduction in noise.
Respondido : 24/04/2017 6:33 am
ken.f2
(@ken-f2)
+1 for the paver idea. Got the same 16x16 paver at Home Depot (listed at 37lbs) with 4 felt-padded feet (2-inch dia) and the printer is much, much quieter! I did build my MK2S kit with DryLin bearings on X & Y.
I'm typing this downstairs and the printer is upstairs in a bedroom with the door open.
Respondido : 02/05/2017 3:38 am
IAmDotorg
(@iamdotorg)
I did the same thing with a slab of granite that had been cut out from a sink when the prior owner of my house was renovating a bathroom, I think.
I had originally been running it on the island in my kitchen, and discovered the same thing -- it was SO much louder on any other surface that wasn't high-mass like that. A few 2" felt feet on the bottom of the granite, and its quiet pretty much anywhere I put it now.
Respondido : 02/05/2017 7:56 pm
norman.d
(@norman-d)
Bought the concrete, but they didn't have rubber feet. Only the cheap stuff that is for the feet of chairs so they glide better (white felt stuff) or a thick EVA foam mat. Is any of those two things good? I'm not into the physics of vibrations :/
Respondido : 12/08/2017 4:52 pm
Rob Nance
(@rob-nance)
It's all about decreasing that resonance that gets passed to your surface. A sturdy piece of furniture works the same way.
Respondido : 18/08/2017 9:31 pm
Intrudermax
(@intrudermax)
If anybody cares, I made a LACK enclosure with some additional height in it to account for the paver. Link to it is here: https://www.thingiverse.com/thing:2449239
If you like it, please feel free to comment.
Respondido : 20/08/2017 9:35 pm
sam.m5
(@sam-m5)
Has anyone tried bolting to the printer to the paver, to secure it more tightly? Does this make noise/vibration better, worse, or no different?
Respondido : 13/11/2017 10:20 pm
richard.l
(@richard-l)
Miembro Moderator
Don't know if it would change the noise/vibration characteristics but it sure would make it much harder to perform maintenance or troubleshoot problems.
Respondido : 14/11/2017 3:10 pm
Página 1 / 2
