Became Loose
I didn't notice that the left nut for y idler came loose on its own. The printer didn't show much of a problem either.
Maybe would be better to have spring washer added between the nut and that flat washer to give tension so the nut won't become loose due to vibrations of the frame. Or Prusa should include them for future mk2
Opublikowany : 27/01/2018 11:51 am
Re: Became Loose
good thing it was just the idle pulley,
two nuts would work to make a jam nut if you have it.
I like to check all my screws and nut every so often to make sure they stay tight out of habit.
Opublikowany : 28/01/2018 1:42 am
