Alu-Heatbed MK3
AnilM3
(@anilm3)
Alu-Heatbed MK3
Hi Everyone,
I've been looking at the Alu-Heatbed MK3 as an upgrade to my printer, I was wondering if anyone has had any experience. For what I can see it can provide higher speeds as the adhesion with the aluminum might be a bit better and given that the glass is not required, the clips aren't either, thus giving a bit of a higher print area. On the other hand, I guess cleaning it might not be as trivial as cleaning the glass and we can't have multiple of them for consecutive prints.
http://reprap.org/wiki/PCB_Heatbed#MK3_ALU-Heatbed_Dual_Power
Any thoughts?
Publié : 09/03/2016 1:16 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Alu-Heatbed MK3
Hi Anil
Ideally with aluminium, you would need Kapton tape/glue/juice or blue tape (this is what I use with a aluminium build plate).
Aluminium is a nice surface to print on, if you can get some sufficiently thin and flat. Otherwise, you will be looking to put glass on top...
Peter
P.S. It may be worthwhile to wait for a while to see if Josef comes up with a better solution.
Publié : 09/03/2016 6:01 pm
AnilM3
(@anilm3)
Re: Alu-Heatbed MK3
Hi Peter,
Thanks for your response!
Are you, by any chance, using an aluminum build plate with the i3?
I guess if the surface is not even and I need to go back to the build plate, I would've gained nothing from the "upgrade".
Publié : 09/03/2016 6:10 pm
PJR
 PJR
(@pjr)
Re: Alu-Heatbed MK3
Hi Anil
No, I am using the aluminium build plate with a clone. Glass on the "original".
If you have to use glass on top of aluminium, you lose out due to the additional mass (lower acceleration factor, slower prints).
Moving parts need to be as light as possible.
Best advice: Make do with the glass for now...
Peter
EDIT: I should add that I have the Mk. 3 Aluminium as a spare...
Publié : 09/03/2016 6:25 pm
