Acrilyc enslosure
daniel.l9
(@daniel-l9)
Acrilyc enslosure
FYI I just got in touch with the Russian team who designed the Acrilyc enclosure on indiegogo, the campain did not got funded, but they replied to me they can sell me the files so I can make my own case
https://www.indiegogo.com/projects/minihood-low-cost-3dprinter-enclosure-and-filter-3d-design #/
I'm aiming for the tall version 50x50x80, so that the complete as is MkII will fit even with the material holder, as well I took the taller version as I expect there will be quite some heat comming from the bed and hopefully this will keep the printer not overheating, as I'm not sure on how the fans will work with the filters.
Any way, I'm still waiting for my printer, so I will keep you updated, but I like on this project the fact I get a PDF that I can send my local Acrilyc shop let it laser cut the holes and dont need to play around CAD or any othere SW I any way dont operate.
Will keep you updated
PS: if the PC fans will not work might go http://www.digikey.com/product-detail/en/OD6038-12HBVXC/1053-1249-ND/2621154 its a high pressure fan
Opublikowany : 22/11/2016 11:08 am
LBussy
(@lbussy)
Cunning Linguist
Re: Acrilyc enslosure
Very cool, please keep us posted.
Bad decisions make good stories
Opublikowany : 30/11/2016 1:48 pm
daniel.l9
(@daniel-l9)
So far I got the drawings and objects to be printed in stl, the fans and electronics will be send in 2 weeks, will keep you posted, I still reached back to the guys as the drawings are missing dimensions of the fan mounts, but other than that all is there, and looks well. Will update once all arrives.
Opublikowany : 03/12/2016 9:55 pm
