Z-Color-Change at a defined Z-Value
3DPrint - YS
(@3dprint-ys)
Hi folks
I want to print a dual-color model. Its a Plate with a Text and Surroud.
The text start at a z value of Z = 4.00 (Plate in black) and then it has 1.00 up to 5.00 (Text in gold)
Due to the fact that i want to print at 0.3mm Layer height, it sets it either at 3.80 or 4.10 what in that particular case, goes wrong because the split has to be at 4.00 precisely.
Does the PS does have a possibility to set a value for the Z-Change? Or can you just setting it by lower the layer height?
I could print it in 0.2mm or 0.1mm in case of need, but for me, its just too long waiting until the change comes...
Or any other ideas to solve it?
regards
Postato : 20/10/2022 8:41 am
JustMe3D
(@justme3d)
RE: Z-Color-Change at a defined Z-Value
Variable Layer Height should do the trick. https://help.prusa3d.com/article/variable-layer-height-function_1750
Postato : 20/10/2022 9:02 am
Pedroid
(@pedroid)
You can change the height of a layer specifically using a  "Height Range Modifier". Just change the layer heigth of the range 3,8 to 4,0 to 0,2.
Postato : 20/10/2022 9:06 am
