XYZ calibration cube
Please see the attached calibration cube, any ideas on how to improve the quality?
Printed at default Slic3r PE speeds, Prusa PLA, 0.1 mm, 220/210 C, 70/65C, stock MK3s only mod is a 5V Noctua fan cooling the extruder motor.
Attachment removed
Napsal : 27/06/2019 7:09 am
RE: XYZ calibration cube
Not really sure what to do but i would check the tension of x-axis and y-axis, what does it says on the screen? Support -> axis
Also i think the temperature is a bit high, with prusament PLA i'm using 215º on nozzle and 60º on bed
How is the first layer calibrated? do you have a photo of the bottom?
Napsal : 27/06/2019 9:26 am
