Wood Filament stringing on external perimiters
Sean
 Sean
(@sean-6)
I'm printing Groot with hatchbox Woddfill PLA at 215c using High Detail settings and it is pretty stringy stuff.
I was wondering if anyone had suggestions on how I could reduce the stringiness especially on his face so I dont have to do more post processing then necessary?
Disregard the layer shift in his head. There was a momentary power drop that resulted in the layer shift. Going to have to re print this one anyway.
Publié : 22/05/2018 4:44 pm
rob.l6
(@rob-l6)
Re: Wood Filament stringing on external perimiters
Well I for one thinks it looks pretty good as is.
But I suppose you could try reducing the temp a little (but beware of blockages), slow down perimeter speed, lower your retraction length and set z lift to zero and see how you go.
Or even try a 0.5 nozzle.
Publié : 23/05/2018 3:35 am
x50arm
(@x50arm)
I can’t remember what settings I used for this one, I wiped out my settings while upgrading the slicer. When I get done with my current print jobs I’ll go back in and figure it out again. Here is how mine turned out.
Publié : 24/05/2018 1:43 am
rob.l6
(@rob-l6)
Nice, which material?
Publié : 24/05/2018 6:34 am
x50arm
(@x50arm)
[/quote]
[/quote]
Pretty sure that one was Tianse, but I also had a roll of Hatchbox at that time. The hatchbox prints a lot lighter color, but I can’t tell for sure in that pick which one it was.
Publié : 25/05/2018 2:52 am
